every half an hour
Posted: Mon Mar 24, 2014 11:50 am
After half a year of successful work of Intence PC in mode 24/7 the problem with regular spontaneous switching-off appeared.
The configuration is the following:
Spontaneous switching-off began to appear about a month ago and had no dependence from time – could work two weeks and could switch off every half an hour. Now exact dependence is found out – switching off every half an hour. To eliminate all possible factors the following was made:
Do you have some suggestions what it might be?
- Intel Celeron (R) CPU 847E 1.1 GHz
- Memory 2x 2048 MB DDR3-1333 – Transcend JM1333KSM-2G
- 8Gb SSD
- The change of power supply unit for the one – doesn’t solve the problem;
- Stress test for system stability with programs SnM и Prime95 – doesn’t find out problems even with 100% download;
- badsectors doesn’t find failure sectors or i/o;
- gauging for new BIOS (the last from official website- CR_2.2.0.400 X64)
- doesn’t change anything, switching-off continue (settings are reset on default);
- Memtest86+ 5.01 failure memory units doesn’t found out (additionally the test with shut off hard disk was made)
