Intense PC power issue
I was attempting to power the Intense PC directly from a 12 volt system. I may have ended up with the polarity reversed. The PC will no longer power up on the 12 volt system or when plugged into 110v ac. Is there anything I can reset?
Re: Intense PC power issue
Hardware is likely to be damaged.
Please consult rma@fit-pc.com about repair service in this case.
