fit-VGA with intense PC
Posted: Thu Nov 08, 2012 4:42 pm
by pj_systech_swe
Is fit-VGA supposed to work with intense PC out of the box?
I get the windows logo and the "Starting Windows" message and then the screen turns black and then i get a "No signal detected" message from the display. If I boot into Safe Mode fit-VGA works as expected, but not with a normal boot. I have tried multiple displays from diffrent manufacturers and they all behave the same.
I have installed the drivers from the download link (http://www.fit-pc2.com/download/Intense ... 7/drivers/).
Re: fit-VGA with intense PC
Posted: Sun Nov 11, 2012 12:01 pm
Fit-VGA is unsupported on the IntensePC series. FitVGA will work only with a drivers that are not depended on a DCC data. Please refer to http://www.fit-pc.com/wiki/index.php/Co ... an_fit-PC2 for an additional information.
Posted: Wed Apr 17, 2013 11:23 am
by opencompany
@Gabriel
How you tested / found any HDMI/DisplayPort adapter to VGA that works out-of-the-box on Intense PC?
Posted: Mon Apr 22, 2013 3:23 pm
Generally, most of an available DP2VGA adapters with EDID emulator on the market are supported.
Posted: Mon Apr 22, 2013 3:28 pm
by opencompany
We have tested the following DisplayPort to VGA converter and can confirm that this is working with Intense PC:
CAC-1002: Club 3D Display Port to VGA adapter
http://www.club-3d.com/index.php/produc ... apter.html
Posted: Wed Jun 05, 2013 5:53 pm
by jean-eric
My company have a industrial PC that connect on a VGA touch screen, the embedded computer is dead, so we buy a intense pc to replace it. I try to make it work with the fit vga cable but after "Starting Windows" message it come dark, it is exactly the problem above. If I connect a HDMI screen and then the fit cable, it work but it is the same after a reboot (all black). I know this is because the display reports to be analog, but the computer output is digital. I try a lot of things, nothing work. I also unistall the driver (I'm on W7_32), try the amd_edid.bat that I found on this forum. Can someone help me?
Posted: Thu Jun 06, 2013 10:34 am
by opencompany
jean-eric wrote:My company have a industrial PC that connect on a VGA touch screen, the embedded computer is dead, so we buy a intense pc to replace it. I try to make it work with the fit vga cable but after "Starting Windows" message it come dark, it is exactly the problem above. If I connect a HDMI screen and then the fit cable, it work but it is the same after a reboot (all black). I know this is because the display reports to be analog, but the computer output is digital. I try a lot of things, nothing work. I also unistall the driver (I'm on W7_32), try the amd_edid.bat that I found on this forum. Can someone help me?
I would suggest the DisplayPort to VGA converter I have mentioned above. We have tested this to work with Intense PC.
CAC-1002: Club 3D Display Port to VGA adapter:
Posted: Thu Jun 06, 2013 6:46 pm
by jean-eric
I have the one sold by your company http://www.fit-pc.com/web/fit-pc/accessories/fit-vga/ Hopefully I buy 2 of them ( one of them isn't working). If I uninstall grafics drivers I let the VGA standart it work I can reboot and the screen is working, but it stuck in 600x480 resolution. I continu to try différent drivers, the ones on your website doesn't work... (it work with a DVI screen).
Posted: Tue Jun 11, 2013 6:22 pm
by jean-eric
I solve my problem by installing a usb to vga card:
http://www.startech.com/AV/USB-Video-Ad ... SB2VGAPRO2
I have to install the driver with a hdmi screen. Whit this card the VGA monitor start working when the operating system start (I don't see the bios). yeah it is 90$ but to save a 1000$ touch screen it worth the cost.
