ata1: COMRESET failed (errno=-16)
zelogik
Post by zelogik »
I have strange bevahior when I want to boot from any usb key, after that the OS start.
the message ata1: COMRESET failed (errno=-16) appear three times.
I have try to install Fedora or Debian an no one can boot on the SSD after installation.
Inside I have put an intel ssd x25-e. incompatibility Issue?
Regards
zelogik
Re: ata1: COMRESET failed (errno=-16)
Post by zelogik »
Yes It's seem that Intel X25-e is not compatible, I have try with and OCZ Core 128Go (the first one from OCZ) and It's seem to work fine.
I have see that the FIT-PC3 have the same problem with some SSD. I hope it's not the same problem (need to change some RC circuit).
Regards
Thank you for submitting this compatibility issue. We will schedule to investigate this issue
