FreeBSD
suroot
FreeBSD
Post by suroot »
Has anyone tested FreeBSD on the IntensePC, does it work out of the box and if not, what is not working?
Thanks in advance!
br,
Chris
Re: FreeBSD
We haven't tested yet FreeBSD on the IntensePC. Other users are welcome to share their experience with the FreeBSD setup in this thread
MrFixit
Re: FreeBSD
Post by MrFixit »
I guess the only problematic piece would be the Wifi chipset. Is it possible to put in a card based on an Atheros chip? These are usually well supported under FreeBSD.
I'm very close to buying one and would report my findings here, but I need to confirm the Wifi chipset issue first ...
Re: FreeBSD
You can always exchange the stock WiFi module with your favorite one
MrFixit
Re: FreeBSD
Post by MrFixit »
Indeed, I got my IntensePC a couple of weeks ago and replaced my aging router/fileserver/thingamabob and so far everything is running smoothly.
Especially pleasant is the RS232 port for debugging or use as a headless terminal.
I had to replace the WLAN+BT module that came with it with an Atheros based card. Sadly, that card is thicker then the other module and I cannot get the clips to really make it stick, I can only hope the hard disk keeps it in place and it doesn't come loose during normal operations.
ath0: <Atheros 9280> mem 0xe0600000-0xe060ffff irq 17 at device 0.0 on pci4
ath0: [HT] enabling HT modes
ath0: [HT] 2 RX streams; 2 TX streams
ath0: AR9280 mac 128.2 RF5133 phy 13.0
ath0: 2GHz radio: 0x0000; 5GHz radio: 0x00c0
nico
Re: FreeBSD
Post by nico »
@MrFixit: What about the display?
Return to “Linux on Intense PC”
