intense pc front panel
Posted: Sun Jan 26, 2014 7:55 pm
by optimus
Hello Everyone,
I have been trying to use intense pc motherboard in a different case for a project which require features of SBC-ISB + some other feature. Found that SBC-ISB does not have a front panel like regular boards, for connecting with the power button, reset button, hdd lead of Case.
So, we need to know how can we use SBC-ISB in different case? Please help.
Re: intense pc front panel
Posted: Wed Jan 29, 2014 5:54 pm
by mbirger
IPC front panel doesn't have power or reset buttons. BTW all of them available on the SBC.
What do you specifically need to achieve?
Posted: Sun Feb 02, 2014 6:14 pm
by optimus
As I said we need to use intense pc board in different case. We were
having difficulty to install different case's power switch. However, we got a technician to do that
wiring power button cable beside intense pc switch.
We also need a pcie card installed and worked inside new case with intense board. We have used a mini pcie converter on mini pcie . This converter require to provide current from fdd/molex connector. It works if we provide current from different pc's fdd/sata power port. We have splitted sata power from sata connector but our pcie does not works. We have found 12v current is not available in sata port/connector of intense board. To populate sata/fdd power we have two ground and a 5V from sata connector but without having 12v our pcie not going to work. Can you please help us to find a 12v source from intense pc board which can be used easily?
Posted: Thu Feb 06, 2014 4:32 pm
by mbirger
Please refer to FACE module HW spec:
http://www.fit-pc.com/wiki/index.php/FA ... umentation
You may find both 12V and 5V on its connectors.
