It would appear that the A55E has a built in 1Gbps Ethernet port.
However, all the fit-PC3 documentation I could find shows that a
Realtek device is in use. For example, this fit-PC3 block diagram;
http://www.fit-pc.com/forum/viewtopic.php?f=75&t=2477
Is the AMD A55E controller hub Ethernet port un-connected?
Or is it wired to the FACE?
If so, that would be an easy way for getting 2 Ethernet ports for
those few people that need 2 but not 5.
Note that I do realize the builtin A55E Ethernet port may not have
the feature set required by the fit-PC3. So an add on chip may have
been selected.
Here is a reference that shows some of the differences between the
AMD A50M and A55E, (page 2);
http://www.amd.com/us/Documents/49282_G ... _brief.pdf
Ethernet port - AMD A55E controller hub
