Help needed for Linux reboot
scotte
Post by scotte »
I have discovered that Windows XP and Windows 7 both successfully signal the pc to reboot when the reboot option is selected in Windows.
But under Linux - Ubuntu through 9.04, and CentOS through 5.3, even with a recent BIOS upgrade, the PC hangs when Linux says it is rebooting. I need to manually press the power switch to shut down the system.
I have yet to try with any of the *BSD family.
Thoughts? Inisghts?
Thanks.
Mylife
Re: Help needed for Linux reboot
Post by Mylife »
1) Open menu.lst :
$ sudo gedit /boot/grub/menu.lst
2) Add reboot=b at the end of the line # defoptions=quiet splash (keep the line commented) :
# defoptions=quiet splash reboot=b
3) Save and close gedit and type :
$ sudo update-grub
4) And eventually :
$ sudo halt
5) Wait for the fit-pc2 to shutdown.
6) Press the power switch on. You're now able to reboot.
7) You can read the whole story here : http://www.fit-pc2.com/forum/viewtopic.php?f=9&t=301
Return to “Linux on fit-PC2”
