Switching between WiFi and Ethernet causes connection delay
brebey
Post by brebey »
When I switch between WiFi and Ethernet, there is an unpredictable delay between the time I bring the new interface up and the time I can once again ping or otherwise connect to a certain destinations on the network.
Usually, these things clear themselves up after as many as 5 minutes.
It isn't the whole network that's unreachable, though...it's only certain addresses. I can always find a couple things to ping on the network; I just can't get to everything right away.
It smells of a caching problem of some sort. I've tried flushing the routing table ["ip route flush table main"] between bringing one interface down and the other up, but that didn't seem to do any good.
Any idea what's causing some addresses not to be reachable when I switch interfaces?
Thanks for any help!
Bill Rebey
prj
Re: Switching between WiFi and Ethernet causes connection delay
Post by prj »
What does it say when running arp?
Return to “Linux on fit-PC2”
