I installed Debian Squeeze on my fit-pc2. All runs ok, so each time I try to fsck a large partition in the internal hard disk, I get this errors:
[ 394.301711] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6
[ 394.301822] ata1.00: BMDMA stat 0x24
[ 394.301913] ata1.00: cmd c8/00:80:31:09:c4/00:00:00:00:00/eb tag 0 dma 65536 in
[ 394.301916] res 51/84:3c:75:09:c4/00:00:00:00:00/eb Emask 0x10 (ATA bus error)
[ 394.302113] ata1.00: status: { DRDY ERR }
[ 394.302187] ata1.00: error: { ICRC ABRT }
[ 394.302294] ata1: soft resetting link
[ 394.481016] ata1.00: configured for UDMA/33
[ 394.481164] sd 0:0:0:0: [sda] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 394.481290] sd 0:0:0:0: [sda] Sense Key : Aborted Command [current] [descriptor]
[ 394.481559] Descriptor sense data with sense descriptors (in hex):
[ 394.481678] 72 0b 47 00 00 00 00 0c 00 0a 80 00 00 00 00 00
[ 394.482469] 0b c4 09 75
[ 394.482749] sd 0:0:0:0: [sda] Add. Sense: Scsi parity error
[ 394.482917] end_request: I/O error, dev sda, sector 197396785
Thank you very much in advance
