Max screen resolution.
Posted: Sun Aug 03, 2014 7:12 pm
by zelogik
I have read that the intense pc pro support dual head up to "Dual head display up to 2560 x 1600"
But can I add three screen with wxga (1280x800 (or more)) side by side?
With one screen connected on the hdmi and two splitted on the display port.
Re: Max screen resolution.
Posted: Tue Aug 05, 2014 3:38 pm
by mbirger
I don't exactly understand how do you plan to split two displays on single DP port. Anyway, you cannot operate 3 displays with two display ports.
BTW, IPC2 has 3 display outputs.
Posted: Wed Aug 20, 2014 11:50 pm
by hwmartin
mbirger, zelogik is probably asking because he plans to use something like the Matrox DualHead2Go ( http://www.matrox.com/graphics/en/produ ... splayport/ ) which splits the incoming image into two separate ones (each with half the horizontal pixels of the original) for spanning across multiple monitors.
ie., 3840x1080 = 1920x1080 + 1920x1080
Unless CompuLab states otherwise I would assume the maximum resolution for the DisplayPort output is around what Matrox lists on their compatibility page for the DualHead2Go:
http://www.matrox.com/graphics/de/suppo ... solutions/
I myself am running a monitor at 2048x1536 off the MintBox 2 DisplayPort without any issues, although the 3D performance at that resolution isn't great.
Posted: Tue Dec 30, 2014 2:53 pm
by zelogik
Little outdated but there is Dual DP spliter to dual Hdmi output like:
http://www.amazon.com/Zotac-DisplayPort ... B005Q9ZNS4
http://fr.startech.com/AV/Repartiteurs/ ... SP122DP2HD
And many more, but I don't know if it's work well with a simple Intense PC pro.
Regards.
