External Power Switch Activation
ClearCut
Post by ClearCut »
We want to activate the intense PC (startup) using an external (extended) power switch. We noticed the unit is powered on whenever it is disconnected and reconnected to the electrical power grid. Is this a basic feature of the device? Can we use that feature by connecting the PC to a 12 Volts DC external switch? Following a conversation with Rona (CompuLab rep.), she mentioned Intel's Virtualization Technology. How does it relate to the issue above?
Thank you,
Zachi
Product Engineer
ClearCut
Re: External Power Switch Activation
You can use power switch to turn the Intense PC off and back on.
Intel AMT available with Intense PC Pro can be used to remotely reset the computer.
ClearCut
Post by ClearCut »
We don't want to use the incorporated switch but rather extended a line to another custom-made switch. Do you see any problem with that?
Sorry I was not clear enough. What you can do is cut the AC power to the computer power supply and then resume it. So the answer is yes, you can build the system as you intended.
ClearCut
Post by ClearCut »
Dear Irad,
Thanks you very much for your support. Can you provide us with a contact number and/or email of the person in charge of technical support for the Intense-PC in case we would encounter future problems/queries ?
Best regards,
Zachi
Support is given through this forum.
Businesses can purchase a technical support contract, but this does not make sense to end users.
