Power & Temperature
Posted: Fri Mar 09, 2012 8:22 pm
by morety
Hello guys,
nice to hear that you are going to release a high-performance Intel machine.
I am curious to know what will be the power consumption range of the Intense devices.
And... I am also curious about the normal operational temperatures. Are they close to the once from the fit-pc2 2GHz?
Re: Power & Temperature
Posted: Sat Mar 10, 2012 10:35 am
Idle power of Intense PC is 8W. Top power depends on configuration, but since the Core i7 supports Turbo Boost power can climb momentarily as high as the thermal envelope allows.
Intense PC has advanced thermal management that monitors both CPU and touch temperature. Under normal workload Intense PC runs cooler than fit-PC2. Under stress test thermal throttling may kick in.
Posted: Mon Mar 26, 2012 4:02 pm
We will perform different tests, and will post the results in a time
Posted: Fri May 25, 2012 12:31 pm
by opencompany
Any news about working temperature range for Intense PC different configurations with HDD and SSD?
Thank you in advance.
Posted: Fri Jun 01, 2012 7:28 am
We are in the final stages of our tests
Posted: Mon Jul 30, 2012 12:53 pm
by alexander
gabrielh wrote:We are in the final stages of our tests
Has there been any progress on this?
Is there a difference between the Intense PC models?
Thanks in advance!
Best regards,
Alex
Posted: Tue Jul 31, 2012 8:51 am
