Display sync fails at warm temperatures
lkbrow1
Post by lkbrow1 »
I have a fitpc3 with an HDMI monitor attach which runs continuously at about 20% load. It is sitting on a small table and when the temperature gets to 75 degrees F The display goes nuts with vertical and horizontal problems. This has happened repetitively with different monitors which were different brands and resolutions. When the temperature goes back to below 73 degrees the display clears up.
Is this a component that is not meeting specification ?
