I just received my Fit-PC3 today. Unpackaged, installed wireless antenna's, hooked up HDMI from Fit-PC3 to TV, plugged in power.
After all the above were done, the screen just goes to a 'Boot Menu' screen (Black screen with gray window with 'Boot Menu' and 'App Menu' tabs at top) with the only option of ATA HDDo:Samsung HM251HI under the 'Boot Menu' tab. App Menu tab is no help.
If I Select the option available, the screen goes blank and comes back to the same window. If i hit ESC (exit), it does the same thing.
Only thing I can think of is I accidentially hit the Power Button on the back just after plugging it in. (The Fit-PC3 was set as boot on power, so I'm assuming I interrupted the initial boot...)
Any help is much appreciated.
-Steven
Problem turning on brand new unit.
Re: Problem turning on brand new unit.
Post by ssrancheri »
I'm actually using the Recovery CD sent with the unit to reinstall windows. It is showing all HD space as available, so perhaps it doesnt come factory installed?
