fit-PC3 not start
kkanjuh
fit-PC3 not start
Post by kkanjuh »
I have problem from begining with fit-PC3. HDMI connection to LCD not show picture. When I connect LCD with HDMI to DVI adaptor I get system to run.
When I try to little move fit-PC3 then system automaticly turn off.
After few days I try to run PC3 again but no picture on screen (I hear that HDD work and green logo is ON).
After few hours I try again and system start to run - I see windows screen that ask me to I choose how to start windows: normal or safe. This screen ususaly is visible when system not proprely shut down.
Then I start windows update. After few minutes (windows update not finish downloading) PC is not show picture only green logo is ON.
After this I cannot start system.
From begining I not see BIOS information.
Could you help me?
Regards,
Krunoslav
Re: fit-PC3 not start
To get the BIOS screen, you should hold the F2 key right after you power on your system. Please hold it until you'll see the BIOS screen.
Please try to use another DVI cable, to see if it's solve the issue.
If nothing of this helps, please consider to RMA
kkanjuh
Post by kkanjuh »
Nothing help. We will send back.
Regards,
Krunoslav
