Audible humming / ticking in fit-PC3
earthping7
Re: Audible humming / ticking in fit-PC3
Post by earthping7 »
I second the motion that the circuit design should be changed to remove the humming/ticking sounds.
This is unwarranted, given that previous generations (fitpc2/2i, fitpc original, slim, etc) did not have this issue. Sitting close (<1m) away, this becomes very annoying and defeats the true purpose of a completely silent pc.
I look forward to ordering soon, once new production run is released (with sound issues fixed).
Hary
Post by Hary »
I totally agree.
Arwen
Post by Arwen »
I have to agree that if the Fit-PC 3 has continuous noise, it's not as suitable
for my use. Currently my old Fit-PC 1, Full Height is about 1 meter away
from my home entertainment center. For practical purposes, it's totally
silent even with a spinning IDE hard drive.
Please consider selling a version that does not include hum or ticking noise.
Arwen Evenstar
Rivendale, Middle Earth
We appreciate the feedback. There is a trade-off between being audible at maximum power saving and being silent at a slightly higher power consumption. This is determined by implementing skip-mode in the switching power supply. fit-PC3 was designed with skip-mode enabled to minimize power consumption. We will check whether skip-mode can be optionally disabled for users who appreciate silence over power saving.
Ziggo
Post by Ziggo »
Yes, please do consider adding such an option. Power saving is not that important to me.
Arwen
Post by Arwen »
Is the power supply that generates the noise internal to the box?
Or external?
This may make a difference for some of us who can place the CPU unit
where noise would be a problem. But can relocate the power supply part
further away.
Arwen Evenstar
bugger
Post by bugger »
Arwen wrote:Is the power supply that generates the noise internal to the box?
Or external?
According to this post it's internal.
mirumu
Post by mirumu »
Or external?
further away.
Sorry for the confusion. There is an external power supply, but I can't say I've heard any noise from it. The ticking noises described come from the Fit-PC3 itself.
To put things in perspective I can't hear the noise at all from about 2 meters away in a near silent room. So yes, if you can relocate it somewhere a bit further away from your ears then this noise would not be a problem at all. Also if there is anything else making noise in the room then you won't hear the Fit-PC3 noise. Almost anything else will drown the noise out. The noise will only really be an issue in a silent room, and if you're close to the unit.
I also just wanted to thank irads for looking into this further. It's a shame there's a trade-off involved, but anything that can be done is welcome.
Arwen
Post by Arwen »
Thanks bugger and mirumu for the clarification.
Arwen Evenstar
monnier
Post by monnier »
irads wrote:We appreciate the feedback. There is a trade-off between being audible at maximum power saving and being silent at a slightly higher power consumption.
I do not understand this tradeoff, but I care about minimizing power usage when idle and minimizing noise when idle as well, even if this comes at the expense of a slightly higher power usage when active, or some minor noise when active.
FWIW, my fit-pc2's idle consumption is probably higher than it should be since I had to disable the extra sleep states in the BIOS (since they cause the fit-pc2 to occasionally fail to wake up for about 5minutes, which is usually seen in the OS's time drifting). So maybe a slightly higher idle consumption is not that terrible.
If the tradeoff could be quantified (at least on the power-consumption side but ideally also on the dB side) it would help.
