Update has caused many problems. How can I roll back?
colinmcc
Post by colinmcc »
I have a mint box pro with cinemon desktop that has been working fine until today when I let it do an update by clicking on the little icon to the bottom right of my desktop. I hadn't done that for a while so it took nearly an hour.
About half way through a message box came up asking something like 'Do you want to overwrite grub with the one contained in the package maintainers update?'
I clicked on continue, and eventually the update finished. After a reboot everything has changed, my icons are in different places and are grey, my desktop looks totally different!
And, worst of all, my left hand monitor a DP++ unit on which I had set rotate Clockwise to view long documents is no longer rotated! When I go to Applications>System Tools>System settings and select Displays, I am given the option to rotate it and when I select for example rotate>Clockwise, I am first told:
The selected configuration for displays could not be applied
with a smaller message: could not set the configuration for CRTC 72.
If I click on close I get another message box saying:
Failed to apply configuration: %s
GDBus.Error:org.gtk.GDBus.UnmappedGError.Quark._gnome_2drr_2derror_2dquark.Code2: could not set the configuration for CRTC 72
I'm guessing that the update included for some reason the package maintainer's personal settings and that I now have their computer's settings pointing at their drivers which are not right for the mint box.
I desparately need to revert back to my own pre-update settings, desktop etc, how can I do this?
Thank you!
Geek by nature.. Linux by choice.. ;-)
colinmcc
Re: Update has caused many problems. How can I roll back?
Post by colinmcc »
I also posted about this at the linux mint forum, rather than my repeating myself here with the saga so far please visit :
http://forums.linuxmint.com/viewtopic.p ... 72#p681172
To see that after 6 hours + I stlll haven't resolved the problem! In fact I now just have both screens mirrored and can't even split the desktop. This is however better than a couple of hours ago when the mouse pointer vanished.. :x
I think(?) that I need a new set of ATI drivers installed to match the Mint Box, and a matching X configuration file, so they all play nicely. And I haven't even started to work out why a simply saying yes to an update this morning changed my desktop, icons, colors etc!
Thank you,
Colin
Dear Colin
Have you tried to manually update the fglrx drivers?
Please try
sudo apt-get install fglrx-updates
colinmcc
Post by colinmcc »
Dear gabrielh
Following another reply from you on this forum I have tried:
sudo apt-get install fglrx-updates xvba-va-driver vainfo
Which resulted in:
colin@Mint-Box-Pro ~ $ sudo apt-get install fglrx-updates xvba-va-driver vainfo
[sudo] password for colin:
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
So I ran: sudo dpkg --configure -a
colin@Mint-Box-Pro ~ $ sudo dpkg --configure -a
Setting up xbmc-pvr-vdr-vnsi (1.0.0~git20130129.2244-96774c4-0precise) ...
Setting up mplayer2 (2.0-426-gc32b3ed-2ubuntu0.1) ...
Setting up xbmc-pvr-dvbviewer (1.0.0~git20130129.2244-96774c4-0precise) ...
Processing triggers for resolvconf ...
resolvconf: Error: /etc/resolv.conf isn't a symlink, not doing anything.
Setting up fglrx-updates (2:9.000-0ubuntu0.1) ...
update-initramfs: deferring update (trigger activated)
Loading new fglrx-updates-9.000 DKMS files...
Building only for 3.2.0-25-generic
Building for architecture amd64
Building initial module for 3.2.0-25-generic
Done.
fglrx_updates:
Running module version sanity check.
 - Original module
   - No original module exists within this kernel
 - Installation
   - Installing to /lib/modules/3.2.0-25-generic/kernel/drivers/char/drm/
depmod........
DKMS: install completed.
Setting up cups-pk-helper (0.2.1.2-1ubuntu0.1) ...
Setting up virtualbox-guest-dkms (4.1.12-dfsg-2ubuntu0.2) ...
Removing old virtualbox-guest-4.1.12 DKMS files...
Deleting module version: 4.1.12
completely from the DKMS tree.
Done.
Loading new virtualbox-guest-4.1.12 DKMS files...
Done.
vboxguest:
 - Original module
 - Installation
   - Installing to /lib/modules/3.2.0-25-generic/updates/
vboxsf.ko:
 - Original module
 - Installation
vboxvideo.ko:
 - Original module
 - Installation
depmod....
Setting up x11-common (1:7.6+12ubuntu2) ...
Setting up xbmc-pvr-argustv (1.0.0~git20130129.2244-96774c4-0precise) ...
Setting up sessioninstaller (0.20+bzr128-0ubuntu1.2) ...
Setting up xbmc-pvr-vuplus (1.0.0~git20130129.2244-96774c4-0precise) ...
Setting up xbmc-pvr-mythtv-cmyth (1.0.0~git20130129.2244-96774c4-0precise) ...
Setting up apt-clone (0.2.2ubuntu2) ...
Setting up ginn (0.2.4.1-0ubuntu1) ...
Setting up xbmc-pvr-nextpvr (1.0.0~git20130129.2244-96774c4-0precise) ...
Processing triggers for libc-bin ...
ldconfig deferred processing now taking place
Setting up xbmc-pvr-njoy (1.0.0~git20130129.2244-96774c4-0precise) ...
Setting up xbmc-bin (2:12.0~git20130129.1036-frodo-0precise) ...
Setting up xbmc-pvr-tvheadend-hts (1.0.0~git20130129.2244-96774c4-0precise) ...
Setting up python-piston-mini-client (0.7.2+bzr57-0ubuntu1) ...
Setting up icedtea-netx-common (1.2-2ubuntu1.3) ...
Setting up python-ubuntu-sso-client (3.0.2-0ubuntu3) ...
Setting up xbmc-pvr-mediaportal-tvserver (1.0.0~git20130129.2244-96774c4-0precise) ...
Setting up pulseaudio-module-bluetooth (1:1.1-0ubuntu15.2) ...
Setting up xserver-common (2:1.11.4-0ubuntu10.8) ...
Setting up xbmc (2:12.0~git20130129.1036-frodo-0precise) ...
Processing triggers for bamfdaemon ...
Rebuilding /usr/share/applications/bamf.index...
Setting up fglrx-amdcccle-updates (2:9.000-0ubuntu0.1) ...
Setting up libreoffice-style-human (1:3.5.4-0ubuntu1.1) ...
Setting up ure (3.5.4-0ubuntu1.1) ...
Setting up initramfs-tools (0.99ubuntu13.1) ...
Setting up language-pack-en (1:12.04+20120801) ...
Setting up perl-modules (5.14.2-6ubuntu2.2) ...
Setting up ntfs-3g (1:2012.1.15AR.1-1ubuntu1.2) ...
Setting up libreoffice-style-tango (1:3.5.4-0ubuntu1.1) ...
Setting up libreoffice-common (1:3.5.4-0ubuntu1.1) ...
Setting up gnome-icon-theme (3.4.0-0ubuntu1.1) ...
Setting up evince (3.4.0-0ubuntu1.4) ...
Setting up gnome-icon-theme-full (3.4.0-0ubuntu1.1) ...
Setting up uno-libs3 (3.5.4-0ubuntu1.1) ...
Setting up language-pack-en-base (1:12.04+20120801) ...
Generating locales...
  en_AG.UTF-8... done
  en_AU.UTF-8... done
  en_BW.UTF-8... done
  en_CA.UTF-8... done
  en_DK.UTF-8... done
  en_GB.UTF-8... done
  en_HK.UTF-8... done
  en_IE.UTF-8... done
  en_IN.UTF-8... done
  en_NG.UTF-8... done
  en_NZ.UTF-8... done
  en_PH.UTF-8... done
  en_SG.UTF-8... done
  en_US.UTF-8... done
  en_ZA.UTF-8... done
  en_ZM.UTF-8... done
  en_ZW.UTF-8... done
Generation complete.
Setting up libgnome2-bin (2.32.1-2ubuntu1.1) ...
Setting up openjdk-6-jre-headless (6b24-1.11.5-0ubuntu1~12.04.1) ...
Installing new version of config file /etc/java-6-openjdk/security/java.security ...
Setting up libmono-security4.0-cil (2.10.8.1-1ubuntu2.2) ...
Setting up openjdk-6-jre (6b24-1.11.5-0ubuntu1~12.04.1) ...
Setting up openjdk-6-jre-lib (6b24-1.11.5-0ubuntu1~12.04.1) ...
Setting up perl (5.14.2-6ubuntu2.2) ...
Setting up language-pack-gnome-en (1:12.04+20120801) ...
Setting up apache2.2-common (2.2.22-1ubuntu1.2) ...
Setting up libgnome2-0 (2.32.1-2ubuntu1.1) ...
Setting up libmono-corlib4.0-cil (2.10.8.1-1ubuntu2.2) ...
Setting up udev (175-0ubuntu9.2) ...
udev stop/waiting
udev start/running, process 7234
Removing 'diversion of /sbin/udevadm to /sbin/udevadm.upgrade by fake-udev'
Setting up icedtea-6-jre-cacao (6b24-1.11.5-0ubuntu1~12.04.1) ...
Setting up ubuntu-minimal (1.267.1) ...
Setting up libreoffice-core (1:3.5.4-0ubuntu1.1) ...
Setting up mysql-client-5.5 (5.5.29-0ubuntu0.12.04.1) ...
Setting up libbonoboui2-0 (2.24.5-0ubuntu1.1) ...
Setting up gstreamer0.10-plugins-base-apps (0.10.36-1ubuntu0.1) ...
Setting up eog (3.4.2-0ubuntu1.1) ...
Setting up libreoffice-math (1:3.5.4-0ubuntu1.1) ...
Setting up language-pack-gnome-en-base (1:12.04+20120801) ...
Setting up brasero (3.4.1-0ubuntu1.1) ...
Setting up icedtea-netx (1.2-2ubuntu1.3) ...
Setting up libmono-system-xml4.0-cil (2.10.8.1-1ubuntu2.2) ...
Setting up libreoffice-java-common (1:3.5.4-0ubuntu1.1) ...
Setting up totem (3.0.1-0ubuntu21.1) ...
Setting up icedtea-6-jre-jamvm (6b24-1.11.5-0ubuntu1~12.04.1) ...
Setting up libreoffice-base-core (1:3.5.4-0ubuntu1.1) ...
Setting up totem-mozilla (3.0.1-0ubuntu21.1) ...
Setting up libreoffice-base (1:3.5.4-0ubuntu1.1) ...
Setting up liblaunchpad-integration1.0-cil (0.1.56.1) ...
* Installing 1 assembly from liblaunchpad-integration1.0-cil into Mono
Setting up libmono-cairo4.0-cil (2.10.8.1-1ubuntu2.2) ...
Setting up apache2-mpm-prefork (2.2.22-1ubuntu1.2) ...
 * Starting web server apache2        apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1 for ServerName
httpd (pid 1801) already running
        [ OK ]
Setting up udisks (1.0.4-5ubuntu2.1) ...
Setting up mono-4.0-gac (2.10.8.1-1ubuntu2.2) ...
Setting up plymouth (0.8.2-2ubuntu31) ...
Setting up libmono-system-security4.0-cil (2.10.8.1-1ubuntu2.2) ...
Setting up apache2 (2.2.22-1ubuntu1.2) ...
Setting up mysql-server-5.5 (5.5.29-0ubuntu0.12.04.1) ...
mysql stop/waiting
mysql start/running, process 7701
Setting up totem-plugins (3.0.1-0ubuntu21.1) ...
Setting up network-manager (0.9.4.0-0ubuntu4.2) ...
Setting up libapache2-mod-php5 (5.3.10-1ubuntu3.5) ...
 * Reloading web server config apache2        apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1 for ServerName
        [ OK ]
Setting up libreoffice-gtk (1:3.5.4-0ubuntu1.1) ...
Setting up php5 (5.3.10-1ubuntu3.5) ...
Setting up python-uno (1:3.5.4-0ubuntu1.1) ...
Setting up libreoffice-draw (1:3.5.4-0ubuntu1.1) ...
Setting up totem-plugins-extra (3.0.1-0ubuntu21.1) ...
Setting up libreoffice-calc (1:3.5.4-0ubuntu1.1) ...
Setting up mysql-server (5.5.29-0ubuntu0.12.04.1) ...
Setting up icedtea-6-plugin (1.2-2ubuntu1.3) ...
Setting up libreoffice-impress (1:3.5.4-0ubuntu1.1) ...
Setting up mono-gac (2.10.8.1-1ubuntu2.2) ...
* Installing 3 assemblies from libappindicator0.1-cil into Mono
* Installing 1 assembly from libdbus-glib1.0-cil into Mono
* Installing 1 assembly from libdbus1.0-cil into Mono
* Installing 6 assemblies from libgconf2.0-cil into Mono
* Installing 13 assemblies from libgdata1.9-cil into Mono
* Installing 1 assembly from libgkeyfile1.0-cil into Mono
* Installing 1 assembly from libglib2.0-cil into Mono
* Installing 1 assembly from libgmime2.6-cil into Mono
* Installing 5 assemblies from libgtk2.0-cil into Mono
* Installing 1 assembly from libgudev1.0-cil into Mono
* Installing 5 assemblies from libmono-addins-gui0.2-cil into Mono
* Installing 15 assemblies from libmono-addins0.2-cil into Mono
* Installing 5 assemblies from libmono-zeroconf1.0-cil into Mono
* Installing 1 assembly from libnotify0.4-cil into Mono
* Installing 2 assemblies from libtaglib2.0-cil into Mono
* Installing 1 assembly from policy.2.10.atk-sharp into Mono
* Installing 1 assembly from policy.2.10.gdk-sharp into Mono
* Installing 1 assembly from policy.2.10.glib-sharp into Mono
* Installing 1 assembly from policy.2.10.gtk-dotnet into Mono
* Installing 1 assembly from policy.2.10.gtk-sharp into Mono
* Installing 1 assembly from policy.2.10.pango-sharp into Mono
* Installing 1 assembly from policy.2.4.atk-sharp into Mono
* Installing 1 assembly from policy.2.4.gdk-sharp into Mono
* Installing 1 assembly from policy.2.4.glib-sharp into Mono
* Installing 1 assembly from policy.2.4.gtk-dotnet into Mono
* Installing 1 assembly from policy.2.4.gtk-sharp into Mono
* Installing 1 assembly from policy.2.4.pango-sharp into Mono
* Installing 1 assembly from policy.2.6.atk-sharp into Mono
* Installing 1 assembly from policy.2.6.gdk-sharp into Mono
* Installing 1 assembly from policy.2.6.glib-sharp into Mono
* Installing 1 assembly from policy.2.6.gtk-dotnet into Mono
* Installing 1 assembly from policy.2.6.gtk-sharp into Mono
* Installing 1 assembly from policy.2.6.pango-sharp into Mono
* Installing 1 assembly from policy.2.8.atk-sharp into Mono
* Installing 1 assembly from policy.2.8.gdk-sharp into Mono
* Installing 1 assembly from policy.2.8.glib-sharp into Mono
* Installing 1 assembly from policy.2.8.gtk-dotnet into Mono
* Installing 1 assembly from policy.2.8.gtk-sharp into Mono
* Installing 1 assembly from policy.2.8.pango-sharp into Mono
Setting up libreoffice-writer (1:3.5.4-0ubuntu1.1) ...
Setting up libreoffice-gnome (1:3.5.4-0ubuntu1.1) ...
Setting up plymouth-theme-ubuntu-text (0.8.2-2ubuntu31) ...
Setting up plymouth-label (0.8.2-2ubuntu31) ...
Setting up libreoffice-help-en-us (1:3.5.4-0ubuntu1.1) ...
Setting up icedtea-plugin (1.2-2ubuntu1.3) ...
Setting up mono-runtime (2.10.8.1-1ubuntu2.2) ...
Setting up libmono-system-configuration4.0-cil (2.10.8.1-1ubuntu2.2) ...
Setting up libmono-system4.0-cil (2.10.8.1-1ubuntu2.2) ...
Setting up libmono-i18n4.0-cil (2.10.8.1-1ubuntu2.2) ...
Setting up libmono-i18n-west4.0-cil (2.10.8.1-1ubuntu2.2) ...
Setting up libmono-sharpzip4.84-cil (2.10.8.1-1ubuntu2.2) ...
Setting up libmono-posix4.0-cil (2.10.8.1-1ubuntu2.2) ...
Setting up libmono-system-drawing4.0-cil (2.10.8.1-1ubuntu2.2) ...
Setting up libmono-system-core4.0-cil (2.10.8.1-1ubuntu2.2) ...
Processing triggers for libreoffice-common ...
Setting up libreoffice-emailmerge (1:3.5.4-0ubuntu1.1) ...
Processing triggers for initramfs-tools ...
update-initramfs: Generating /boot/initrd.img-3.2.0-25-generic
Warning: No support for locale: en_CA.utf8
Then I again ran: sudo apt-get install fglrx-updates xvba-va-driver vainfo
Reading package lists... Done
Building dependency tree
Reading state information... Done
vainfo is already the newest version.
xvba-va-driver is already the newest version.
fglrx-updates is already the newest version.
The following packages were automatically installed and are no longer required:
  libsdl-mixer1.2 libmikmod2
Use 'apt-get autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 25 not upgraded.
I restarted the mint box pro, and my screens are both 'on' but are mirrored.
If I go to Menu>System Tools>System Settings>Displays I see the mirrored box is ticked. If I untick it then small icons of both my screens show up but clicking apply causes both screens to go black, and after waiting for several minutes for the screens to reappear I hit the power switch to turn the mint box pro off and reboot. Grrrrrrrrrrrrrrr!
My xorg.conf in etc/x11/ contains:
Section "ServerLayout"
	Identifier     "amdcccle Layout"
	Screen      0  "aticonfig-Screen[0]-0" 0 0
EndSection
Section "Module"
EndSection
Section "Monitor"
	Identifier   "aticonfig-Monitor[0]-0"
	Option	    "VendorName" "ATI Proprietary Driver"
	Option	    "ModelName" "Generic Autodetecting Monitor"
	Option	    "DPMS" "true"
EndSection
Section "Monitor"
	Identifier   "0-DFP2"
	Option	    "PreferredMode" "1680x1050"
	Option	    "TargetRefresh" "60"
	Option	    "Position" "0 0"
	Option	    "Rotate" "normal"
	Option	    "Disable" "false"
EndSection
Section "Monitor"
	Identifier   "0-DFP1"
	Option	    "Position" "1680 0"
EndSection
Section "Device"
	Identifier  "aticonfig-Device[0]-0"
	Driver      "fglrx"
	Option	    "Monitor-DFP2" "0-DFP2"
	Option	    "Monitor-DFP1" "0-DFP1"
	BusID       "PCI:0:1:0"
EndSection
Section "Device"
	Identifier  "amdcccle-Device[0]-1"
	Driver      "fglrx"
	BusID       "PCI:0:1:0"
	Screen      1
EndSection
Section "Screen"
	Identifier "aticonfig-Screen[0]-0"
	Device     "aticonfig-Device[0]-0"
	DefaultDepth     24
	SubSection "Display"
		Viewport   0 0
		Virtual   3360 1920
		Depth     24
	EndSubSection
EndSection
Section "Screen"
	Identifier "amdcccle-Screen[0]-1"
	Device     "amdcccle-Device[0]-1"
	DefaultDepth     24
		Viewport   0 0
		Depth     24
	EndSubSection
EndSection
Which may help?
All my icons are still different from before, both in cinnamon panel and file manager, firefox, gimp etc, I am very wary of EVER using the update feature again!
Thanks for your help, and yes, I still need to 'fix' the displays at least, I can live with the icons for now. I am lost with only one screen. :cry:
colinmcc
Post by colinmcc »
The version of :xrandr:
colin@Mint-Box-Pro ~ $ xrandr -v
xrandr program version 1.3.5
Server reports RandR version 1.3
And the output of: xrandr
Screen 0: minimum 320 x 200, current 1680 x 1050, maximum 3360 x 1920
DFP1 connected 1680x1050+0+0 (normal left inverted right x axis y axis) 474mm x 296mm
1680x1050 59.9*+
1400x1050 59.9
1280x1024 75.0 60.0
1440x900 59.9
1280x960 60.0
1280x800 60.0
1152x864 59.9 75.0
1280x768 60.0
1280x720 60.0
1024x768 75.0 70.1 60.0
1024x600 75.0 70.1 60.0
800x600 72.2 75.0 60.3 56.2
800x480 72.2 75.0 60.3 56.2
640x480 75.0 72.8 67.0 59.9
DFP2 connected 1680x1050+0+0 (normal left inverted right x axis y axis) 531mm x 299mm
1680x1050 50.0 + 60.0*
1920x1080 60.0 + 50.0 59.9 30.0 25.0 30.0
1600x1200 60.0
1776x1000 50.0 59.9 25.0 30.0
1400x1050 60.0 50.0
1600x900 60.0 50.0
1280x1024 50.0 75.0 60.0
1440x900 50.0 59.9
1280x960 50.0 60.0
1366x768 50.0 59.8
1360x768 50.0 59.8
1152x864 50.0 59.9 75.0
1280x768 50.0 60.0
1280x720 60.0 50.0 59.9
1024x768 50.0 75.0 70.1 60.0
1152x648 50.0 59.9
1024x600 50.0 75.0 70.1 60.0
800x600 50.0 72.2 75.0 60.3 56.2
800x480 50.0 72.2 75.0 60.3 56.2
720x480 50.0 60.0 59.9
640x480 50.0 75.0 72.8 66.6 59.9
CRT1 disconnected (normal left inverted right x axis y axis)
And xrandr in verbose mode which may contain more information?:
colin@Mint-Box-Pro ~ $ xrandr --verbose
DFP1 connected 1680x1050+0+0 (0x98) normal (normal left inverted right x axis y axis) 474mm x 296mm
Identifier: 0x95
Timestamp: 35628
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 1
CRTCs: 1 0
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
EDID_DATA:
00ffffffffffff004c2d0d033232454d
1b110103802f1e782ad515a455499a27
145054bfef80b30081808140714f0101
0101010101017c2e90a0601a1e403020
3600da281100001a000000fd00384b1e
510e000a202020202020000000fc0053
796e634d61737465720a2020000000ff
0048394c503730333730390a202000bd
SignalFormat: TMDS
ConnectorType: HDMI
1680x1050 (0x98) 119.0MHz +HSync -VSync *current +preferred
h: width 1680 start 1728 end 1760 total 1840 skew 0 clock 64.7KHz
v: height 1050 start 1053 end 1059 total 1080 clock 59.9Hz
1400x1050 (0x99) 119.0MHz +HSync -VSync
h: width 1400 start 1728 end 1760 total 1840 skew 0 clock 64.7KHz
1280x1024 (0x9a) 135.0MHz +HSync +VSync
h: width 1280 start 1296 end 1440 total 1688 skew 0 clock 80.0KHz
v: height 1024 start 1025 end 1028 total 1066 clock 75.0Hz
1280x1024 (0x9b) 108.0MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 64.0KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.0Hz
1440x900 (0x9c) 119.0MHz +HSync -VSync
h: width 1440 start 1728 end 1760 total 1840 skew 0 clock 64.7KHz
v: height 900 start 1053 end 1059 total 1080 clock 59.9Hz
1280x960 (0x9d) 108.0MHz +HSync +VSync
h: width 1280 start 1376 end 1488 total 1800 skew 0 clock 60.0KHz
v: height 960 start 961 end 964 total 1000 clock 60.0Hz
1280x800 (0x9e) 108.0MHz +HSync +VSync
v: height 800 start 961 end 964 total 1000 clock 60.0Hz
1152x864 (0x9f) 119.0MHz +HSync -VSync
h: width 1152 start 1728 end 1760 total 1840 skew 0 clock 64.7KHz
v: height 864 start 1053 end 1059 total 1080 clock 59.9Hz
1152x864 (0xa0) 108.0MHz +HSync +VSync
h: width 1152 start 1216 end 1344 total 1600 skew 0 clock 67.5KHz
v: height 864 start 865 end 868 total 900 clock 75.0Hz
1280x768 (0xa1) 108.0MHz +HSync +VSync
v: height 768 start 961 end 964 total 1000 clock 60.0Hz
1280x720 (0xa2) 108.0MHz +HSync +VSync
v: height 720 start 961 end 964 total 1000 clock 60.0Hz
1024x768 (0xa3) 78.8MHz +HSync +VSync
h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.0KHz
v: height 768 start 769 end 772 total 800 clock 75.0Hz
1024x768 (0xa4) 75.0MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1328 skew 0 clock 56.5KHz
v: height 768 start 771 end 777 total 806 clock 70.1Hz
1024x768 (0xa5) 65.0MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.4KHz
v: height 768 start 771 end 777 total 806 clock 60.0Hz
1024x600 (0xa6) 78.8MHz +HSync +VSync
v: height 600 start 769 end 772 total 800 clock 75.0Hz
1024x600 (0xa7) 75.0MHz -HSync -VSync
v: height 600 start 771 end 777 total 806 clock 70.1Hz
1024x600 (0xa8) 65.0MHz -HSync -VSync
v: height 600 start 771 end 777 total 806 clock 60.0Hz
800x600 (0xa9) 50.0MHz +HSync +VSync
h: width 800 start 856 end 976 total 1040 skew 0 clock 48.1KHz
v: height 600 start 637 end 643 total 666 clock 72.2Hz
800x600 (0xaa) 49.5MHz +HSync +VSync
h: width 800 start 816 end 896 total 1056 skew 0 clock 46.9KHz
v: height 600 start 601 end 604 total 625 clock 75.0Hz
800x600 (0xab) 40.0MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.9KHz
v: height 600 start 601 end 605 total 628 clock 60.3Hz
800x600 (0xac) 36.0MHz +HSync +VSync
h: width 800 start 824 end 896 total 1024 skew 0 clock 35.2KHz
v: height 600 start 601 end 603 total 625 clock 56.2Hz
800x480 (0xad) 50.0MHz +HSync +VSync
v: height 480 start 637 end 643 total 666 clock 72.2Hz
800x480 (0xae) 49.5MHz +HSync +VSync
v: height 480 start 601 end 604 total 625 clock 75.0Hz
800x480 (0xaf) 40.0MHz +HSync +VSync
v: height 480 start 601 end 605 total 628 clock 60.3Hz
800x480 (0xb0) 36.0MHz +HSync +VSync
v: height 480 start 601 end 603 total 625 clock 56.2Hz
640x480 (0xb1) 31.5MHz -HSync -VSync
h: width 640 start 656 end 720 total 840 skew 0 clock 37.5KHz
v: height 480 start 481 end 484 total 500 clock 75.0Hz
640x480 (0xb2) 31.5MHz -HSync -VSync
h: width 640 start 656 end 696 total 832 skew 0 clock 37.9KHz
v: height 480 start 481 end 484 total 520 clock 72.8Hz
640x480 (0xb3) 27.3MHz -HSync +VSync
h: width 640 start 664 end 728 total 816 skew 0 clock 33.4KHz
v: height 480 start 481 end 484 total 499 clock 67.0Hz
640x480 (0xb4) 25.2MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.5KHz
v: height 480 start 490 end 492 total 525 clock 59.9Hz
DFP2 connected 1680x1050+0+0 (0xc1) normal (normal left inverted right x axis y axis) 531mm x 299mm
Identifier: 0x96
Timestamp: 35628
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 0
CRTCs: 1 0
filter:
EDID_DATA:
00ffffffffffff000469942401010101
0a160104a5351e783a9265a655559f28
0d5054bfef00714f818081409500a940
b300d1c00101023a801871382d40582c
4500132b2100001e000000fd00324c1e
5311000a202020202020000000fc0056
453234380a20202020202020000000ff
0043334c4d51533035353431380a0151
SignalFormat: DisplayPort
ConnectorType: DisplayPort
1680x1050 (0xb5) 148.5MHz +HSync +VSync +preferred
h: width 1680 start 2448 end 2492 total 2640 skew 0 clock 56.2KHz
v: height 1050 start 1084 end 1089 total 1125 clock 50.0Hz
1920x1080 (0xb6) 148.5MHz +HSync +VSync +preferred
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.5KHz
v: height 1080 start 1084 end 1089 total 1125 clock 60.0Hz
1920x1080 (0xb7) 148.5MHz +HSync +VSync
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 56.2KHz
v: height 1080 start 1084 end 1089 total 1125 clock 50.0Hz
1920x1080 (0xb8) 148.4MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.4KHz
v: height 1080 start 1084 end 1089 total 1125 clock 59.9Hz
1920x1080 (0xb9) 74.2MHz +HSync +VSync Interlace
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 33.8KHz
v: height 1080 start 1085 end 1095 total 1125 clock 30.0Hz
1920x1080 (0xba) 74.2MHz +HSync +VSync Interlace
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 28.1KHz
v: height 1080 start 1085 end 1095 total 1125 clock 25.0Hz
1920x1080 (0xbb) 74.2MHz +HSync +VSync Interlace
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 33.7KHz
1600x1200 (0xbc) 162.0MHz +HSync +VSync
h: width 1600 start 1664 end 1856 total 2160 skew 0 clock 75.0KHz
v: height 1200 start 1201 end 1204 total 1250 clock 60.0Hz
1776x1000 (0xbd) 148.5MHz +HSync +VSync
h: width 1776 start 2304 end 2348 total 2640 skew 0 clock 56.2KHz
v: height 1000 start 1004 end 1009 total 1125 clock 50.0Hz
1776x1000 (0xbe) 148.4MHz +HSync +VSync
h: width 1776 start 1864 end 1908 total 2200 skew 0 clock 67.4KHz
v: height 1000 start 1004 end 1009 total 1125 clock 59.9Hz
1776x1000 (0xbf) 74.2MHz +HSync +VSync Interlace
h: width 1776 start 2304 end 2348 total 2640 skew 0 clock 28.1KHz
v: height 1000 start 1005 end 1015 total 1125 clock 25.0Hz
1776x1000 (0xc0) 74.2MHz +HSync +VSync Interlace
h: width 1776 start 1864 end 1908 total 2200 skew 0 clock 33.7KHz
v: height 1000 start 1005 end 1015 total 1125 clock 30.0Hz
1680x1050 (0xc1) 146.2MHz -HSync +VSync *current
h: width 1680 start 1784 end 1960 total 2240 skew 0 clock 65.3KHz
v: height 1050 start 1053 end 1059 total 1089 clock 60.0Hz
1400x1050 (0xc2) 162.0MHz +HSync +VSync
h: width 1400 start 1664 end 1856 total 2160 skew 0 clock 75.0KHz
v: height 1050 start 1201 end 1204 total 1250 clock 60.0Hz
1400x1050 (0xc3) 148.5MHz +HSync +VSync
h: width 1400 start 2448 end 2492 total 2640 skew 0 clock 56.2KHz
1600x900 (0xc4) 162.0MHz +HSync +VSync
v: height 900 start 1201 end 1204 total 1250 clock 60.0Hz
1600x900 (0xc5) 148.5MHz +HSync +VSync
h: width 1600 start 2448 end 2492 total 2640 skew 0 clock 56.2KHz
v: height 900 start 1084 end 1089 total 1125 clock 50.0Hz
1280x1024 (0xc6) 148.5MHz +HSync +VSync
h: width 1280 start 2448 end 2492 total 2640 skew 0 clock 56.2KHz
v: height 1024 start 1084 end 1089 total 1125 clock 50.0Hz
1440x900 (0xc7) 148.5MHz +HSync +VSync
h: width 1440 start 2448 end 2492 total 2640 skew 0 clock 56.2KHz
1440x900 (0xc8) 106.5MHz -HSync +VSync
h: width 1440 start 1520 end 1672 total 1904 skew 0 clock 55.9KHz
v: height 900 start 903 end 909 total 934 clock 59.9Hz
1280x960 (0xc9) 148.5MHz +HSync +VSync
v: height 960 start 1084 end 1089 total 1125 clock 50.0Hz
1366x768 (0xca) 148.5MHz +HSync +VSync
h: width 1366 start 2448 end 2492 total 2640 skew 0 clock 56.2KHz
v: height 768 start 1084 end 1089 total 1125 clock 50.0Hz
1366x768 (0xcb) 85.5MHz +HSync +VSync
h: width 1366 start 1436 end 1579 total 1792 skew 0 clock 47.7KHz
v: height 768 start 771 end 774 total 798 clock 59.8Hz
1360x768 (0xcc) 148.5MHz +HSync +VSync
h: width 1360 start 2448 end 2492 total 2640 skew 0 clock 56.2KHz
1360x768 (0xcd) 85.5MHz +HSync +VSync
h: width 1360 start 1436 end 1579 total 1792 skew 0 clock 47.7KHz
1152x864 (0xce) 148.5MHz +HSync +VSync
h: width 1152 start 2448 end 2492 total 2640 skew 0 clock 56.2KHz
v: height 864 start 1084 end 1089 total 1125 clock 50.0Hz
1152x864 (0xcf) 148.4MHz +HSync +VSync
h: width 1152 start 2008 end 2052 total 2200 skew 0 clock 67.4KHz
v: height 864 start 1084 end 1089 total 1125 clock 59.9Hz
1280x768 (0xd0) 148.5MHz +HSync +VSync
1280x720 (0xd1) 74.2MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 45.0KHz
v: height 720 start 725 end 730 total 750 clock 60.0Hz
1280x720 (0xd2) 74.2MHz +HSync +VSync
h: width 1280 start 1720 end 1760 total 1980 skew 0 clock 37.5KHz
v: height 720 start 725 end 730 total 750 clock 50.0Hz
1280x720 (0xd3) 74.2MHz +HSync +VSync
v: height 720 start 725 end 730 total 750 clock 59.9Hz
1024x768 (0xd4) 148.5MHz +HSync +VSync
h: width 1024 start 2448 end 2492 total 2640 skew 0 clock 56.2KHz
1152x648 (0xd5) 74.2MHz +HSync +VSync
h: width 1152 start 1592 end 1632 total 1980 skew 0 clock 37.5KHz
v: height 648 start 653 end 658 total 750 clock 50.0Hz
1152x648 (0xd6) 74.2MHz +HSync +VSync
h: width 1152 start 1262 end 1302 total 1650 skew 0 clock 45.0KHz
v: height 648 start 653 end 658 total 750 clock 59.9Hz
1024x600 (0xd7) 148.5MHz +HSync +VSync
v: height 600 start 1084 end 1089 total 1125 clock 50.0Hz
800x600 (0xd8) 148.5MHz +HSync +VSync
h: width 800 start 2448 end 2492 total 2640 skew 0 clock 56.2KHz
800x480 (0xd9) 148.5MHz +HSync +VSync
v: height 480 start 1084 end 1089 total 1125 clock 50.0Hz
720x480 (0xda) 148.5MHz +HSync +VSync
h: width 720 start 2448 end 2492 total 2640 skew 0 clock 56.2KHz
720x480 (0xdb) 27.0MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.5KHz
v: height 480 start 489 end 495 total 525 clock 60.0Hz
720x480 (0xdc) 27.0MHz -HSync -VSync
v: height 480 start 489 end 495 total 525 clock 59.9Hz
640x480 (0xdd) 148.5MHz +HSync +VSync
h: width 640 start 2448 end 2492 total 2640 skew 0 clock 56.2KHz
640x480 (0xde) 26.8MHz -HSync +VSync
h: width 640 start 656 end 720 total 800 skew 0 clock 33.4KHz
v: height 480 start 483 end 487 total 502 clock 66.6Hz
Identifier: 0x97
Timestamp: 35628
Subpixel: unknown
Clones:
CRTCs: 1 0
filter:
SignalFormat: VGA
ConnectorType: VGA
colinmcc
Post by colinmcc »
Well, I'm running out of ideas! After nearly two days I still can't un-mirror my screens let alone rotate one.
Since this month's LFX magazine has feature article on the mint box and mint, with a bootable coverdisk of mint 14 I thought I'd boot from it and see if A. It works, and B if both monitors are working properly I'd copy the x config file created and try that.
BUT..
I put the cover disk in an external usb drive, plug it in and reboot.
I get the select a live distro menu from the disk as expected, ( so USB ports are enabled, and boot from USB too) BUT... at that point in the sequence I'm told to move through the options with my tab key but my USB keyboard is disabled and so my tab key, enter key etc do not work!
I've found on occasion in the past with other older hardware that I had to plug in a PS2 keyboard if I wanted to interrupt a boot sequence before the USB drivers were active, but since the mint box has no ps2, and the boot from the external USB drive is working I am at a loss.
So, I sit there looking at all these live distros to try but am unable to select or try one! ;-(
All I can do at that point is hit the power switch to shut down, unplug the drive then boot again as normal, back into my defective installation.
I have now also tried booting with cover disks from other LFX mags and Linux Pro Magazine, same problem, no keyboard active to continue once the menu comes up.
Have you any advice as to why/how to enable my keyboard before the cover disk splash screen comes up?
Edit: Gooling leads me to this https://bugzilla.redhat.com/show_bug.cgi?id=782347
Which indicates it has been a known bug for some time. Yet another thing that needs 'fixing'..
sesterce
Post by sesterce »
Did you try to plug the keyboard in a different USB port?
I have no problem booting and using USB DVD drives or flashdrives. My keyboard is attached to one of the back USB2 ports, the ones between line-in and rj-45. Don't use any USB3 ports.
Regards,
Jean
colinmcc
Post by colinmcc »
Jean, Thanks..That's where my keybd is plugged in, the cd/dvd drive is in one of the front ones.
I made sure that legacy mode is enabled in the bios. I also notice that on boot up with no external drive enabled I also can't move up/down the grub boot menu since my keyboard doesn't work at that point. So I can't move down to select recovery mode or mem test for example. (Before the 'upgrade' I never saw that menu(?) )
I have to wait 'till the countdown timer gets to zero then boot continues.
On the other matter:
Using the AMD catalyst control center I have managed to split my screens (they are no longer mirrored, although I can't do that from the System Settings> Display menu), and rotate the DP++ one, BUT: Applications eg firefox open and fit full screen on the DP++ screen, ditto on the hdmi screen, yet the desktop background image on the dp++ screen floods half way over the hdmi screen.
gabrielh is there a help line I can call and perhaps arrange to have/purchase a new hard drive with fresh install of the OS? I'm beginning to think that Thursdays 'update' trashed this OS beyond the point where I with my limited knowledge can 'fix' it .. :cry: I really don't want to have to buy 'another' mint box pro to get a working one.
Since the keyboard issue means I can't boot/reload from a new version on CD/DVD even that option is closed.
colinmcc
Post by colinmcc »
PS Just rebooted the mint box... After reboot the screens have become mirrored again, as per the System Settings> Display menu setting I couldn't change before. :x
Had to go into the AMD Catalyst Control Center and change it all again..
Now I don't dare update or reboot!!! :x :x :x
Dear Colin
I suggest you to make a fresh install of Linux Mint 13. We will thoroughly investigate the update issue with a dual head setup, and I will update you with our conclusions.
