Using Fit PC3 for voip services
Posted: Mon Jun 11, 2012 2:37 pm
by carlo78
Hello
i would like to buy fit PC3 to use it for voip services.
What should i buy (model of fit PC,card or other things) to make that?
Can you help me for these informations?
Where can i find technical informations where to see inside fit PC3 if it is possible to install card to make it functions for voip services?
Regards.
Re: Using Fit PC3 for voip services
Posted: Mon Jun 11, 2012 3:08 pm
by igor
as VOIP is not very demanding on performance, fit-PC3 Basic should suit this application quite nicely.
You can choose either Linux or Windows - there are many VOIP software solutions for both. O/S selection should be done based on your background and experience.
"fit-PC3 Basic 4GB Win7 Home Premium" model should be suitable for Windows. "fit-PC3 Basic 4GB Linux" model is recommended for Linux.
In case, the system setup requires to separate the VOIP connection from a general purpose network connection, you can also consider the "fit-PC3 LP 4GB Linux FM-E4U" which adds a second network port to the system.
Best Regards,
Igor.
Posted: Mon Jun 11, 2012 10:37 pm
by carlo78
I am interested to know if fit PC3 has possibility to install expansion cards pci /pcie.
It is possible to install this card "Digium TDM410" or other tipe of these cards?
Regards.
Posted: Tue Jun 12, 2012 10:34 pm
by igor
The fit-PC3 cannot accommodate PCIe cards. Only mini PCIe cards can be used.
Regards,
Igor.
