PCIe Faceplate
Posted: Mon May 21, 2012 8:45 pm
Can you verify that the FACE PCIe interface is a single 4 lane PCIe buss and not 4 one lane buses? Your documentation is unclear on this. Also is the plug a standard PCIe 4 lane outlet?
Support forum for users of C-LAB Edge Computing Division
https://www.fit-iot.com/forum/
That is an interesting idea that we did not consider yet. Do you have a particular application in mind for such a FACE Module?I wish that particular FACE module had dual mSATA instead of just dual mini-PCIe. (mSATA uses the same form factor as a full sized mini-PCIe but adds in the option to use the slot for a mSATA device instead of a mini-PCIe device.)
Yes and no.igor wrote:That is an interesting idea that we did not consider yet. Do you have a particular application in mind for such a FACE Module?Arwen wrote:I wish that particular FACE module had dual mSATA instead of just dual mini-PCIe. (mSATA uses the same form factor as a full sized mini-PCIe but adds in the option to use the slot for a mSATA device instead of a mini-PCIe device.)
