storage
jerry
storage
Post by jerry »
What is the maximum the PC3 Pro can handle of SSD size?
Arwen
Re: storage
Post by Arwen »
It would appear that both the 2.5" SATA drive slot and the mSATA
drive slot use the same SATA controller chip, thus same drivers. So
it would likely be 144PB, (PetaByte = 1024 terabytes). See ATA-6:
http://en.wikipedia.org/wiki/AT_Attachm ... imitations
Of course, the OS may limit the sizes due to partition table or file
system limitations.
Now if you are referring to physical size, the mSATA standard has
that fixed. I don't know the 2.5" SATA drive slot's maximum height.
Arwen Evenstar
Rivendale, Middle Earth
Re: storage
This is standard size supported by SATA-III interface
jerry
Re: storage
Post by jerry »
Sorry all... I worded the question badly.
And thanks for your response, Arwen.
I was indeed speaking of drive capacity, not physical size.
Gabriel, when you say 'this', what are you referring to?
Re: storage
FitPC3's SATA controller
