Using fit-VGA with fit-PC3 in Windows XP
Andy
Post by Andy »
Hi there,
I have 5 questions regarding fit-VGA and fit-PC3:
1) Does it work with Windows XP ?
2) If it works, then does XP need to be patched like Windows 7 ?
3) If Windows XP does need to be patched, does it use the same patch and installation method as Windows 7 (i.e. http://fit-pc.com/forum/viewtopic.php?f=77&t=2644) ?
These next questions apply to both Windows XP and Windows 7:
4) When using fit-VGA, do we still get the full benefit of hardware acceleration ?
5) After having patched Windows 7 or XP (if applicable), is it possible to simply unplug the VGA monitor and attach an HDMI or DVI monitor instead, without having to un-intstall the patch ?
Thanks once again for your help
Andy
Re: Using fit-VGA with fit-PC3 in Windows XP
Hi Andy
Here are your answers
1) Yes. It was tested with WinXP
2) Please use the attached patch with the instructions from the Windows 7 post
3) Refer paragraph 2
4) Yes
5) In most cases yes, but if you have a problem, you'll need to remove the EDID emulation registry entry to get the correct EDID data
amd_edid.zip
(651 Bytes) Downloaded 382 times
Return to “fit-PC3 accessories”
