This procedure require some basic tech skill, and extra care. In a case of failure, this will void your warranty, so please make it on your own risk.
To do so please remove the memory modules and PM me the the picture of the board beneath the modules
BIOS reset
Re: BIOS reset
Re: BIOS reset
We have a fit-PC3 Pilot-batch unit with a similar issue.
It boots to a "white" shell screen but without keyboard support.
So we are not able to press Esc for exit or change anything else.
Any way to get around this or should we either RMA the unit or maybe try a BIOS reset as well?
Thanks in advance.
Thanks in advance.
Kind Regards,
Kevin Peter Gade
Kevin Peter Gade
Re: BIOS reset
Ok. Could you send me instructions for that.gabrielh wrote:Please try a BIOS reset firstly
Do you need any information / picture to do so?
Thanks.
Kind Regards,
Kevin Peter Gade
Kevin Peter Gade
Re: BIOS reset
Please check your inbox for an instructions
Re: BIOS reset
Same issue w/ my fitPC3, please send me instructions. Thank you very much~!
Best Regards
Best Regards
Re: BIOS reset
Dear Takenaka
Please contact me with your issue by PM
Re: BIOS reset
Could you please send me the instructions as well?
Mine was working fine last night, went to start it this morning and it doesn't have any video out (so no screen) and doesn't seem to be responding to the keyboard either
I had a look at how to reset the bios on the main board but the battery is soldered and I can't see any jumper anywhere.
Peter
Edit: I measured the CMOS battery voltage and its 2.84 volts, this is a little on the low side isn't it?
Peter
Re: BIOS reset
Please note that hard resetting BIOS involves some technical skills and may void your warranty. You can contact me directly by PM for instructions.
Re: BIOS reset
Hello Guys,
I also need a hint, I can manage the technical side and I understand the warranty issue, no problem.
Only thing, I use IntensePC. Story is here: (http://www.fit-pc.com/forum/viewtopic.php?f=96&t=4986).
So, please let me know the way, how to manage it in Fit-PC3, I am interesting to check it in IntensePC.
Thank you in advance!
István
István
