DDR3 supported version
gilles76
Post by gilles76 »
according to the http://www.amd.com/us/Documents/49282_G ... _brief.pdf we have :
T40N-T40E LDVDDR3-1066 (and I guess DDR3-1066)
In the Fitpc3 spec. you mention : DDR3-1333.
Since I'm not *very* familiar with the memory differences, which versions should I buy and put inside?
Regards,
Gilles
redpost
Re: DDR3 supported version
Post by redpost »
We are planning on using Kingston SODIMM modules for our Fit-PC3s. According to this note on the Fit-PC3 website:
• Some DDR3 SODIMM modules may not work with fit-PC3 pilot batch. It is recommended to use only the SODIMM modules supplied with the unit
What is the spec of modules that will work?
Any pair of DDR3-1066 / 1333 or LVDDR3 -1066 / 1333 should work.
With T40N/T40E CPUs the 1333 memory will be operated at 1066 frequency
Note that this should be SODIMM-204pin form factor
Return to “fit-PC3 hardware”
