What are the maximum surface temperatures that have been measured on the highest performance fit-pc3's while under load?
Surface temperatures
Re: Surface temperatures
We implement measurement of the touch temperature and adjusting power/performance to keep temperature within range.
Default max temperature would be 50C.
Cool,
That should be controlled via ACPI right, or is it built into the bios? So what happens when i install my own linux OS, I would like to be able to override any cpu throttling.
If run without any throttling under high load for extended periods, how hot would the case get? would it melt / cause a thermal shutoff of the cpu?
So there are sensors built into the case? Can these be accessed from the OS?irads wrote:We implement measurement of the touch temperature and adjusting power/performance to keep temperature within range.
Under normal operation we do not expect throttling to take place. The sensors are installed on the motherboard and are being contacted by the case. They are being monitored by ACPI through BIOS and can be read by the OS.
Temperature of a fanless system is very dependent on both system load and the environment - mostly the temperature and mobility of of surrounding air.
There is no risk of thermal shutdown, skin burn or melting of the metal case. The goal of the sensing is to keep touch temperature at comfortable level and ensure stable operation of hard disk and memory.
