1. Does the diskless fit-pc3 contain any moving part?
2. Are you planning to distribute a fit-pc3 model with a SSD?
3. I've read the fit-PC3 Specifications PDF I found in other post. There I noticed fit-pc3 supports up to 8 GB RAM. However, I don't see any model with that configuration. Similarly, the "Internal 2.5 inch hard disk" is displayed as "Configurable" but in the order page I only see a 250 GB HDD or none.
This leads to the following question: Will I be able to buy model "fit-PC3 Basic 4GB" without wifi (which the specifications states is optional) or will I have to choose between "fit-PC3 Basic 4GB" and "fit-PC3 Value 2GB"?
Thanks in advance.
Model customization
Re: Model customization
No moving parts.1. Does the diskless fit-pc3 contain any moving part?
Yes.2. Are you planning to distribute a fit-pc3 model with a SSD?
The solution is to buy barebone and purchase the preferred memory and hard disk separately.3. I've read the fit-PC3 Specifications PDF I found in other post. There I noticed fit-pc3 supports up to 8 GB RAM. However, I don't see any model with that configuration. Similarly, the "Internal 2.5 inch hard disk" is displayed as "Configurable" but in the order page I only see a 250 GB HDD or none.
The challenge we are facing is which configurations to stock. We currently specified 14 and it is likely to grow to 20 or more. We offer build-to-order, but only for minimum volume - not for single units.This leads to the following question: Will I be able to buy model "fit-PC3 Basic 4GB" without wifi (which the specifications states is optional) or will I have to choose between "fit-PC3 Basic 4GB" and "fit-PC3 Value 2GB"?
The solution would be to purchase with WiFi and disable it or take it out.
