fit-PC3 Pro cannot restart from sleep
Takenaka
Post by Takenaka »
Using win7 (64 bit), fit-PC3 Pro cannot restart properly from sleep state.
When depressed power button, it will restart and then soon go to POST screen automatically.
OS is Win7 64bit, BIOS: SCT 2.1.0.333_12, using latest Win7 drivers.
4 units used by a customer are found this issue. Is there any information to fix this?
Re: fit-PC3 Pro cannot restart from sleep
I have some questions regard this issue
1. Is this a clean Windows 7 installation?
2. Does the customer has additional Fit-PC3s except the ones with the issue?
3. What is the peripherals attached to the Fit-PC3s?
Takenaka
Post by Takenaka »
1. Yes, just clean installation.
2. All the units he has are found same problem. He has no other normal units.
3. Only a mouse and a keyboard are attached via USB.
Do you know same symptom?
Takenaka wrote:1. Yes, just clean installation.
The symptoms are unknown. We haven't observed such FitPC3 Pro behavior before. Lets try to isolate the problem to the FitPC3s hardware.
Do you use the a stock HDD and DDR modules, or your own?
Please try to reproduce this issue with an Ubuntu 12.04 Live CD
