New Fit-PC3, WiFi not working on Win7
Pepper
Post by Pepper »
Hi!
I bought a barebone Fit PC3, inserted a 500GB SATA, and installed Win7 Enterprise from a USB stick. Installed LAN, Video and other Drivers successfully. All Windows updated have run through now.
Only WiFi seems not to be working yet. I used the Driver at http://www.fit-pc2.com/download/fit-PC3/Win7/drivers/.
Screenshot of the Device Manager is attached. It Shows under "Other devices" an unkown "Network controller".
Right clicking and letting it search for an updated driver in the directory where the WiFi driver has been unzipped does not help. Running Setup.exe in both directories in the driver package does not help.
What should I do?
Thanks in advance!
Pepper
Re: New Fit-PC3, WiFi not working on Win7
Please post your WiFi PID and VID information
Pepper
Post by Pepper »
Thanks - where do I find this Information?
1. Control Panel\Device Manager\Unknown Device
2. Mouse right click - Properties
3. Pick the details tab and Hardware Ids from the dropbox
Pepper
Post by Pepper »
Thanks - here they are:
PCI\VEN_10EC&DEV_8723&SUBSYS_872310EC&REV_00
PCI\VEN_10EC&DEV_8723&CC_028000
and two lines with shorter versions of the above.
Your help is appreciated.
Pepper
Please use the QCOM driver from here http://www.fit-pc2.com/download/fit-PC3 ... .12.04.zip
Pepper
Post by Pepper »
Hi!
I had used that one before, and installed both the Azurewave and the QCOM Setup.exe, each several times.
Upon your post I made a clean Win7 install from scratch, downloaded from your link again, and just used the QCOM\Setup.exe - no Change. When I use "update Driver" and select the QCM folder to look for a driver, it does not find any compatible driver.
Any further idea, or are we looking at hardware failure here?
Many thanks
Pepper
Pepper
Post by Pepper »
Hi there,
any new ideas?
Another thought: Can I buy the WiFi module for Fit PC3 separately? Which one should I buy? (I am considering getting a barebone without WiFi module and adding the WiFi manually).
Pepper
That is very strange. We are unable to reproduce your problem with this card. What windows version do you use (x86, x64 , localized etc)?
Sure. You should look for a full or half size mini PCIe WiFi network adapter
jgkl
Post by jgkl »
Hello
I got same win7x64 issue with wifi.
Tryede with win8x64 and there it worked.
But software to be run dictates Win7x64
