OpenCL very slow
adrianr
OpenCL very slow
Post by adrianr »
I am using OpenCL on the GPU of a fitpc3 pro running Ubuntu 12.04 64bit for some real time data processing.
Unfortunately, I am having issues with the launch time for my OpenCL kernels (the time between a kernel being added by the CPU onto the OpenCL queue and the kernel sstarting to be executed on the GPU). I have attached a sample OpenCL program to this post that prints out average launch times for some test kernels.
On other machines I own, launch time are around 0.1ms time, yet on the fit3, they are between 8 -23ms. this large delays prevents to fit3 being used for any real time purposes. I have been posting on the AMD forums (see post: http://devgurus.amd.com/thread/166587) and it seems that it could be a problem with the amd drivers/GPU chip or some hardware configuration.
As the fitpc3s are advertised as supporting OpenCL - is there anything specifically in the fitpc hardware design or bios settings that could possibly cause this issue?
cltest.zip
(2.39 KiB) Downloaded 763 times
Re: OpenCL very slow
fit-PC3 should reflect the OpenCL capabilities of the incorporated APU. System builders have very little influence on OpenCL performance. I am not familiar with a BIOS setting that affects OpenCL execution latency.
Return to “Linux on fit-PC3”
