Can't get 2560x1600 on Fit-PC3?
tjls
Post by tjls »
I have a Fit-PC3 -- *not* a Fit-PC3i -- that I'm trying to use to build a kiosk-style embedded control station with a millitary surplus ruggedized 30" LCD touchscreen display.
The display reports two resolutions by DPMS, its native 2560x1600 and a scaled 1280x800. My Macbook Pro happily runs this display at 2560x1600.
I'm using a DisplayPort to dual-link DVI cable with the Fit-PC3 but seem to be limited to 1280x800 resolution. I am using Debian Jesse with the firmware-linux-nonfree package installed. The "Monitors" preferences panel shows 1280x800 as the only available resolution.
Does anyone actually have a Fit-PC3 running at 2560x1600 under Linux? How did you do it?
Re: Can't get 2560x1600 on Fit-PC3?
Your request has been forwarded to a Linux expert.
Denis
Post by Denis »
2560 x 1600 should work.
Please try to intall proprietry fglrx package:
sudo apt-get install fglrx-driver
I'm not sure if you need to add some repository maybe
In any case you can try Linux Mint on temporary storage:
http://www.fit-pc.com/wiki/index.php/Fi ... ux_Mint_17
Compulab's Linux support
Return to “Linux on fit-PC3”
