fit-PC or fitlet with RISC-V64GC processor?
Arwen
Post by Arwen »
You guys already have most of what is needed for a computer with an Open Sourced CPU.
At present, no one else makes a desktop RISC-V computer. There is one that can be turned into a desktop computer, but it's clumsy and costly. At present, everything else is for IoT or other embedded uses. (Like what nVidia and Western Data are doing.)
Without a usable desktop, (or small server), RISC-V software development for kernel and support hardware is going slowly.
If you make it was the same I/O as say a fit-PC4, that would allow the new computer to be quite usable. Perhaps not fine tuned as existing, (and not as fast).
So what do you think?
Arwen Evenstar
Rivendale, Middle Earth
tamir
Re: fit-PC or fitlet with RISC-V64GC processor?
Post by tamir »
Thank you for your suggestion.
Compulab also has an embedded product line, with RISC CPUbased systems.
Products such as the IoT gateways:
https://www.compulab.com/products/iot-gateways/
derek
Post by derek »
This wish list item was asking for not just any RISC architecture CPU (like MIPS or ARM) but specifically for the CPU architecture known, perhaps confusingly, as "RISC-V".
https://en.wikipedia.org/wiki/RISC-V
Of the three products in your link, two of them are apparently ARM-based (so RISC, yes, but not RISC-V) and one of them is apparently Intel (so presumably CISC, i.e. not RISC at all, but the wish list wasn't highlighting RISC v. CISC but RISC-V v. everything else).
The key difference is in the openness philosophy and, at a more practical level, the licensing arrangements.
Return to “Wish list”
