Mintbox3 Wish list
ARXD
Mintbox3 Wish list
Post by ARXD »
I have the Mintbox2, and it is awesome when it come to value vs price!
If Compulab will ever consider Mintbox3, this is what I wish they will improve:
Hit dissipation:
1. Add folding small legs on the bottom of the device,
raising the device a 1/2" will allow more airflow for hit dissipation as hot air underneath the device will moves up (and out), replaced by colder air.
(I raised my Mintbox2 using a small simple mesh tray, and the temperature drop is noticeable)
2. m-sata SSD by default, will also help keeping the temperature down.
Functionality:
1. Use the Linux Mint logo on the front as a power button.
2. 4 USB-3, 2 in the back and 2 in the front
3. Bootable CF card reader on the front panel (I WISH)
4. Programmable IR (off/on) in the face module
5. IR Remote Control that fully support Linux Mint / XBMC! (yee I know.. I know... but it is a wish list after all, so why not add it?)
Do not change list:
1. USB spaces on the front module is perfect!
*not all USB devices has a standard thickness top size, and the space between the USB slots make it very easy to plug and unplug peripherals!
2. Connectivity! 8 USB slots are very welcome! also the 2 LAN! the more Connectivity, the better!
3."Linux Mint Cinnamon" is a beautiful Linux distribution, as a former Ubuntu user thank you for introducing it to me!
Please always keep and support Linux OS! It is hard to find manufacturer that have a full Linux support out of the box when it come to hardware!
Thank you!
Re: Mintbox3 Wish list
Thanks for the thoughtful feedback.
I assure you it was read thoroughly.
Best regards,
Chief Product Officer
CompuLab
Return to “Wish list”
