I would definitely like to have a remote on/off input together with the power supply connector (I know it consumes space, maybe a 3.5 mm connector would help here)
3rd pin for remote on if 12V is applied, bios configurable reaction when the pin goes to 0V.
This would help in unattended installations to get the fit into a defined mode of operation after e.g. main supply outage.
if this is implemented the USB should definitely also be un-powered (they seem to remain powered in new version), if in off mode, to avoid battery drain.
kuno
Power on/off considerations and USB power in off state
