Build with a Front Power Button
Dual Ethernet, 5.1 Audio, Standard HDMI... post here everything fit-PC2 does not have and you wish it had. We listen.
anandrkris
Post by anandrkris »
Hi - I am currenty using Mint Box II as my desktop and have a suggestion to make. The current power button, placed on rear side, is not that easily accessible. Perhaps, the existing logo square (Mint logo in my case) can be made button-like so that power switch becomes evident and easy to operate from the front. (Not sure if it is easily doable engineering wise and if it poses any design constraints or if it is deliberately built this way for a reason!)
Thanks, for an otherwise cool design. :)
Re: Build with a Front Power Button
Thanks for the idea. We will take it into consideration, however there are several mechanical and geometries constraints.
anandrkris
Cool. Thanks for your consideration. :)
Return to “Wish list”
