Error message when trying to start OS
manoka
Post by manoka »
Recently I tried to make a new installation of the Mint 9 OS on my fit-PC2i.
Then suddenly the following message appeared:
"error: too small lower memory (0x99100 > 0x90000)
Failed to boot both default and fallback entries"
Now nothing seems to work anymore - not even the (F) commands in the BIOS.
I wonder whether this could be an issue with the on-board 4GB flash disk - which is the only HD I'm usually using.
In case it needs to be sent to repair, do I have to send it to the reseller where I bought it, or to CompuLab in Israel?
Info would be appreciated very much!
manoka
ev0lsan
Re: Error message when trying to start OS
Post by ev0lsan »
Have you tried a memory scan?
I think its a memory problem.
Ev0lsan
manoka
Post by manoka »
Thanks Ev0lsan!
How could I do a memory scan?
When I start up the computer, this message shows up right away and all functions are blocked.
I can only get into the BIOS, but no commands are possible there either.
manoka
Are you able to navigate through the BIOS? Is the keyboard ok?
manoka
Post by manoka »
The keyboard works fine with another computer - which I'm using to write this post.
Thus, yes, I can navigate through the BIOS - there it's only the "F..." commands which don't work.
manoka
Post by manoka »
I just tried another keyboard. The "F..." commands in the BIOS are working with this one. I set the BIOS to the default configuration.
But still no difference with the OS - neither the one I had installed, nor the Live version I tried to access via a bootable USB pen drive.
Either way, only the mentioned message is showing up.
Please consider to RMA the product
manoka
Post by manoka »
I already considered to RMA the product to the reseller.
Here is his reply:
"This has nothing to do with hardware. Just google on your mistake and you see messages like this: https://answers.launchpad.net/ubuntu/+s ... ion/135875
Your mint installation is causing problems….
Please also check support on Compulab site: http://www.fit-pc.com/forum/viewforum.php?f=13
Good luck!"
What is the S/N of your FitPC2? Is this a FitPC2 or FitPC2i?
manoka
Post by manoka »
It is a FitPC2i.
Serial number: 100202-009
Return to “Linux Mint”
