Solved: Unable to install dhcp3-server on Linux Fit-PC2i
PhB
Post by PhB »
Here is my attempt to get and install this server :
mint-fitpc2 apt # cat /etc/apt/sources.list
deb http://packages.linuxmint.com/ helena main upstream import
deb http://archive.ubuntu.com/ubuntu/ karmic main restricted universe multiverse
deb http://archive.ubuntu.com/ubuntu/ karmic-updates main restricted universe multiverse
deb http://security.ubuntu.com/ubuntu/ karmic-security main restricted universe multiverse
deb http://archive.canonical.com/ubuntu/ karmic partner
deb http://packages.medibuntu.org/ karmic free non-free
deb http://fit-pc2.com/download/ubuntu/dists/karmic binary/
deb-src http://fit-pc2.com/download/ubuntu/dists/karmic source/
mint-fitpc2 apt # apt-get install dhcp3-server
Reading package lists... Done
Building dependency tree
Reading state information... Done
Suggested packages:
dhcp3-server-ldap apparmor
The following NEW packages will be installed:
dhcp3-server
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 373kB of archives.
After this operation, 872kB of additional disk space will be used.
WARNING: The following packages cannot be authenticated!
dhcp3-server
Authentication warning overridden.
Err http://archive.ubuntu.com karmic-updates/main dhcp3-server 3.1.2-1ubuntu7.1
404 Not Found [IP: 91.189.92.171 80]
Err http://security.ubuntu.com karmic-security/main dhcp3-server 3.1.2-1ubuntu7.1
404 Not Found [IP: 91.189.92.167 80]
Failed to fetch http://security.ubuntu.com/ubuntu/pool/ ... 1_i386.deb 404 Not Found [IP: 91.189.92.167 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
mint-fitpc2 apt #
Looking at the package repository, it appears that there is no dhcp3-server_3.1.2-1ubuntu7.1_i386.deb file but dhcp3-server_3.1.2-1ubuntu7_i386.deb (w/o ".1" before i386). Can you tell me where I can find a package server with the correct dhcp3-server ? ?
Thanks for you attention and help,
PhB.
PhB
Post by PhB »
Here is how I’ve solved my issue.
1- Using the graphical admin tool, I’ve de-installed packages dhcp3-client and dhcp3-common 3.1.2-1ubuntu7.1
2- With my favourite browser I’ve downloaded
3- http://archive.ubuntu.com/ubuntu/pool/m ... 3_i386.deb
4- http://archive.ubuntu.com/ubuntu/pool/m ... 3_i386.deb
5- http://archive.ubuntu.com/ubuntu/pool/m ... 3_i386.deb
6- Then manually installed these 3 packages
# dpkg –I dhcp3*7.3*.deb
I’m OK now with my Fit-PC2i running as an AP and DHCP server. I’ve been a ble to connect my iPhone and Galaxy Android tablet.
Hope this might help somebody,
PhB.
Return to “Linux Mint”
