Wireless card not visable
Re: fit-PC2i 1600 I just installed Mint 9 and there is no option to enable the wireless. Wired LAN OK. Just un-installed 10.04 LTS and there was a visible card, but it showed "disconnected" in Ubuntu. In Mint it shows non existent in menu. System is updated and this is my first interaction with the forum. Thanks in advance!
Re: Wireless card not visable
Hi
Please follow this instruction after install
http://fit-pc2.com/wiki/index.php/Insta ... nux_Mint_9
It seems you didn't update linux kernel
Thank you for the reply. Regarding this:
* Add the following lines to /etc/apt/sources.list
deb http://fit-pc2.com/download/ubuntu/dists/lucid binary/
deb-src http://fit-pc2.com/download/ubuntu/dists/lucid source/
Each has several options such as; Binary or source, then package.gz, libva...., linux headers, linux source, mplayer, xserver, etc.
Which do I select for deb and deb-src?
And, is "/etc/apt/sources.list " a file that i ad them physically into?
Please open terminal
run #sudo gedit /etc/apt/sources.list
at the bottom of the file add
Just copy-paste
Save the file and exit gedit
Just copy-paste
The process went as instructed but no obvious improvements. "Enable Networking" and "Enable Notifications" are both checked as before without word of wireless selection. The bios is booting everything upon startup except a cdrom and still there is no indication of the pci-e wireless capability.
I have done everything below:
Required system changes
- Add the following lines to /etc/apt/sources.list
Code:
- Refresh update manager
Code:
sudo apt-get update
- Install kernel image, kernel headers, graphic drivers and media player for HD playback:
Code:
sudo apt-get install linux-image-2.6.35-34-fitpc2 linux-headers-2.6.35-34-fitpc2 xserver-xorg-video-poulsbo mplayer-vaapi mplayer-skins
- Remove generic image and sources that are not fully compatible with fit-PC2.
Code:
sudo apt-get purge linux-generic linux-image-generic linux-headers-generic linux-image-$(uname -r) linux-headers-$(uname -r) && sudo apt-get autoremove
- Restart fit-PC2
Code:
Code:
sudo apt-get update
Code:
Code:
- Restart fit-PC2
I started over again, default bios and everything. After installing, I
accessed /etc/apt/sources.list and looks like this now:
deb http://packages.linuxmint.com/ isadora main upstream import
deb http://archive.ubuntu.com/ubuntu/ lucid main restricted universe multiverse
deb http://archive.ubuntu.com/ubuntu/ lucid-updates main restricted universe multiverse
deb http://security.ubuntu.com/ubuntu/ lucid-security main restricted universe multiverse
deb http://archive.canonical.com/ubuntu/ lucid partner
deb http://packages.medibuntu.org/ lucid free non-free
#deb http://archive.getdeb.net/ubuntu lucid-getdeb apps
#deb http://archive.getdeb.net/ubuntu lucid-getdeb games
I then immediately did "sudo apt-get update"
Code:
Code:
NOW: Changes are not applied to the monitor because of an x server problem.
Boot up slow
No WiFi card visible.
Please read over my sources list to make sure I cut and pasted what I needed to, how I needed to. If none of this works, I need to know if I've typed something wrong above.
Code:
Code:
Boot up slow
Hi
Can you perform a clean install? I mean format partitions during linux mint installation, and the follow the after installation steps
Wireless card (if there is no hardware failure) should appear upon click on network icon
Thanks for the ideas. My most recent effort was a clean install without partitions, allowing the installing program to select the entire drive deleting anything that was already there. If you could read through my last posts and not find any script errors, then I did it all verbatim. Earlier installations of 10.04 LTS could recognize the existence of my PCI wireless card but needed to be "connected". Mint is not seeing the PCi card at all. This is the "USA-Japan Distribution (32-bit)" ISO.
Re: Wireless card not visable > sudo mintwifi
Here are the results of sudo /usr/lib/linuxmint/mintWifi/mintWifi.py below;
* I. scanning WIFI PCI devices...
* II. querying ndiswrapper...
* III. querying iwconfig...
lo no wireless extensions.
eth0 no wireless extensions.
eth1 no wireless extensions.
wlan0 IEEE 802.11bgn ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=8 dBm
Retry long limit:7 RTS thr:off Fragment thr:off
Encryption key:off
Power Management:on
* IV. querying ifconfig...
eth0 Link encap:Ethernet HWaddr 00:01:c0:08:87:96
inet addr:192.168.1.66 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::201:c0ff:fe08:8796/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:409 errors:0 dropped:0 overruns:0 frame:0
TX packets:435 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:224651 (224.6 KB) TX bytes:96598 (96.5 KB)
Interrupt:24 Base address:0x2000
eth1 Link encap:Ethernet HWaddr 00:01:c0:08:87:97
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:25 Base address:0xc000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:32 errors:0 dropped:0 overruns:0 frame:0
TX packets:32 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:2160 (2.1 KB) TX bytes:2160 (2.1 KB)
wlan0 Link encap:Ethernet HWaddr 00:0d:f0:8d:f3:77
* V. querying DHCP...
Internet Systems Consortium DHCP Client V3.1.3
Copyright 2004-2009 Internet Systems Consortium.
All rights reserved.
For info, please visit https://www.isc.org/software/dhcp/
Listening on LPF/wlan0/00:0d:f0:8d:f3:77
Sending on LPF/wlan0/00:0d:f0:8d:f3:77
Listening on LPF/eth1/00:01:c0:08:87:97
Sending on LPF/eth1/00:01:c0:08:87:97
Listening on LPF/eth0/00:01:c0:08:87:96
Sending on LPF/eth0/00:01:c0:08:87:96
Sending on Socket/fallback
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 7
DHCPOFFER of 192.168.1.66 from 192.168.1.254
DHCPREQUEST of 192.168.1.66 on eth0 to 255.255.255.255 port 67
DHCPACK of 192.168.1.66 from 192.168.1.254
bound to 192.168.1.66 -- renewal in 33772 seconds.
* VI. querying nslookup google.com...
Server: 192.168.1.254
Address: 192.168.1.254#53
Non-authoritative answer:
Address: 74.125.224.51
Address: 74.125.224.50
Address: 74.125.224.49
Address: 74.125.224.48
Address: 74.125.224.52
Encryption key:off
Power Management:on
Re: Wireless card not visable. Half way there
Now - Wireless Networks checked, but indicating disconnected and shaded. This similar "disconnected" status was achieved while 10.04 LTS was installed.
How can I reconnect this and see available WiFi signals? The provided threaded omni antenna is in place.
Thanks in advance.
Thanks in advance.
