Page 1 of 3
Linux Mint 9 is officially supported
Posted: Tue Nov 30, 2010 3:50 pm
by Denis
Hi all,
Linux Mint 9 Isadora is officially supported. It`s LTS (Long Term Support) release, similar to Ubuntu 10.04.
There is a new graphic driver available - EMGD IntelĀ® Embedded Media and Graphics Driver. In comparison with previous IEGD drivers:
- Better 2D, 3D (Visual Effects) support.
- Suspend/Resume working.
In comparison with PSB drivers:
- Xv video playback works fine.
Prepare installation media
- You can use USB CD-ROM Drive or USB Flash drive (disk-on-key) as installation media.
- Download Linux Mint 9 "Isadora" - Gnome CD (32-bit).
- If you are using USB CD-ROM - burn downloaded image directly on CD.
- If you are using USB Flash drive, 1GB would be enough, use "Startup Disk Creator" utility to create LiveUSB.
Installation of generic Linux Mint 9
- Standard Linux Mint installation - choose timezone, partitions, username, password etc.
- Unplug USB CD-ROM / USB Flash drive and reboot
- Login using previously selected username and password
Required system changes
- Add the following lines to /etc/apt/sources.list
## Repository for fit-PC2 users provided by Compulab
deb http://fit-pc2.com/download/ubuntu/dists/lucid binary/
deb-src http://fit-pc2.com/download/ubuntu/dists/lucid source/
- Refresh update manager
sudo apt-get update
- Install kernel image, kernel headers, graphic drivers and media player for HD playback:
sudo apt-get install linux-image-2.6.35-34-fitpc2 linux-headers-2.6.35-34-fitpc2 xserver-xorg-video-poulsbo mplayer-vaapi mplayer-skins
- Remove generic image and sources that are not fully compatible with fit-PC2.
sudo apt-get purge linux-generic linux-image-generic linux-headers-generic linux-image-$(uname -r) linux-headers-$(uname -r) && sudo apt-get autoremove
- Restart fit-PC2
Linux Mint 9 is now installed.
Known issues:
- There is no OSD/subtitles support in mplayer-vaapi.
- Visual Effects can cause buggy windows representation. Set Preferences->Appearance->Visual Effects to "None"
Re: Linux Mint 9 is officially supported
Posted: Wed Dec 01, 2010 12:53 pm
by jlsail
Good work
New to linux so ubuntu/mint doesnt matter for me.
Followed your installation guid...worked perfect!
thanks
Johan
Posted: Fri Dec 10, 2010 1:43 pm
by mgg
Hi all,
I am new with Linux and so my question could be stupid.
Can I also use other versions of Linux Mint "Isadora" for the installation like Linux Mint 9 "Isadora" - Gnome DVD (32-bit) ?
Thanks!
Posted: Sat Dec 11, 2010 6:12 pm
by jens
Thanks for making this installation available to us! I have a bit of experience
to share:
1) In order to get resolution compatible with my monitor, I had to change my xorg.conf so the "Screen" section became:
Section "Screen"
Identifier "Screen0"
Device "Card0"
Monitor "Monitor0"
SubSection "Display"
Depth 24
Modes "1920x1080"
EndSubSection
DefaultDepth 24
EndSection
2) compiz messes up my screen, so I removed it completely:
Ctrl+Alt+F1
login as user
sudo stop gdm
sudo apt-get remove compiz*
3) In a terminal I ran
gconftool-2 --set /apps/metacity/general/reduced_resources --type bool true
gconftool-2 --set /desktop/gnome/interface/enable_animations --type bool false
After these change I am very happy running mint on my fitpc2 rev. 1.21
Posted: Thu Dec 23, 2010 3:42 pm
by manoka
Denis wrote:
"Required system changes
Code:
As I'm looking for "/etc/apt/sources.list", I'm getting this message:
"E: Unable to locate package /etc/apt/sources.list
Files:
Package `/etc/apt/sources.list' is not installed.
Use dpkg --info (= dpkg-deb --info) to examine archive files,
and dpkg --contents (= dpkg-deb --contents) to list their contents.
So what exactly should be done to add the code, i.e. the code needs to be added where, and how can I get there?
In the mean time I already did the update.
Is it absolutely necessary to update after adding the code above?
Audio still doesn't work.
Posted: Sat Dec 25, 2010 10:19 pm
by lucian
does this new driver from intel works with hyperthreading on ?
Posted: Sun Dec 26, 2010 3:39 pm
by Denis
does this new driver from intel works with hyperthreading on?
Yes, EMGD drivers working with hyperthreading enabled, at least still we have not found any issues with it.
Posted: Mon Jan 03, 2011 6:19 pm
by Koen
What has changed in the Lucid fitpc2 kernel update from December 30th? I.e. the update from .1 to .2?
Posted: Mon Jan 03, 2011 6:59 pm
by Denis
From .1 to .2 fixed Ralink rt3070 firmware.
Posted: Sun Jan 09, 2011 9:08 pm
by manoka
jens wrote:Thanks for making this installation available to us! I have a bit of experience
to share:
Section "Screen"
Device "Card0"
Monitor "Monitor0"
Depth 24
Modes "1920x1080"
EndSubSection
DefaultDepth 24
EndSection
Ctrl+Alt+F1
login as user
sudo stop gdm
Many thanks jens!
I wouldn't have been able to use the browser without your advice "2)".
I don't know how to program "1)" and "3)", nor whether I need to.
But for now it appears that everything is working just fine - finally!!! - except for the speed of my recently upgraded internet connection (Vodafone mobile), which now should be up to 4,0Mbps, but I usually still get less than 50Kbps (pretty much the same as before the upgrade).
Gratefully
manoka
