How to apply CompuLab repository
manoka
Re: How to apply CompuLab repository
Post by manoka »
After pasting the Code, it looks like this:
_________________________________________________________________________
GNU nano 2.2.2 File: /etc/apt/sources.list
deb http://packages.linuxmint.com/ isadora main upstream import
deb http://archive.ubuntu.com/ubuntu/ lucid main restricted universe multiverse
deb http://archive.ubuntu.com/ubuntu/ lucid-updates main restricted universe mu$
deb http://security.ubuntu.com/ubuntu/ lucid-security main restricted universe $
deb http://archive.canonical.com/ubuntu/ lucid partner
deb http://packages.medibuntu.org/ lucid free non-free
#deb http://archive.getdeb.net/ubuntu lucid-getdeb apps
#deb http://archive.getdeb.net/ubuntu lucid-getdeb games
File Name to Write:$sts/lucid source/
^G Get Help M-D DOS Format M-A Append M-B Backup File
^C Cancel M-M Mac Format M-P Prepend
^X is not an option, so I tried: M-A Append
Right after typing M (it makes no difference what is typed after the M), it reads at the lowest part:
Save file under DIFFERENT NAME ?
Y Yes
N No ^C Cancel
If I type N, it returns to the previous - which means, I still can't exit and close the terminal.
I tried to type Y, then the terminal gets closed, but when checking whether the lines were added, they are not on the list.
lucian
Post by lucian »
ok, instead of nano try gedit
> gedit etc/apt/sources.list
you should now get an editor with frontend, maybe u more comfortable with that.
manoka
Post by manoka »
With your command I got a read only list - so I wasn't able to add and save the codes.
Then I tried: sudo gedit /etc/apt/sources.list
This way I was able to add and save the lines like this:
deb http://fit-pc2.com/download/ubuntu/dists/lucid binary/
deb-src http://fit-pc2.com/download/ubuntu/dists/lucid source/
Please inform me in case this is not OK like this.
Return to “Linux Mint”
