mplayer and hd movie "Bug Buck Bunny" crash
alexandre17220
Post by alexandre17220 »
Hi all,
I have installed mint 9 like the specified in the fitpc2 wiki (http://www.fit-pc2.com/wiki/index.php?t ... nux_Mint_9)
So I have desactived desktop visual effect and I have downloaded http://www.bigbuckbunny.org/index.php/download/
The version 1920*1080 in mp4, when I launch mplayer in command line :
mplayer -vo vaapi -a.avi
I have renamed the video into a.avi.
mplayer return error :
 zzzz@zzzz-laptop ~/Bureau/videos $ mplayer -vo vaapi a.avi
bt_audio_service_open: connect() failed: Connection refused (111)
MPlayer UNKNOWN-4.4.3 (C) 2000-2010 MPlayer Team
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Playing a.avi.
AVI file format detected.
[aviheader] Video stream found, -vid 0
[aviheader] Audio stream found, -aid 1
AVI: ODML: Building ODML index (2 superindexchunks).
VIDEO:  [FMP4]  1920x1080  24bpp  24.000 fps  12000.8 kbps (1464.9 kbyte/s)
Clip info:
 Software: AVI-Mux GUI 1.17.7, Aug  8 2006  20:59:17
libva: libva version 0.31.0
libva: va_getDriverName() returns 0
libva: Trying to open /usr/lib/dri/emgd_drv_video.so
Intel(R) Embedded Media and Graphics Driver 1.5 Build 1742
libva: va_openDriver() returns 0
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
[VD_FFMPEG] VA API accelerated codec.
[VD_FFMPEG] Trying pixfmt=1.
Movie-Aspect is undefined - no prescaling applied.
VO: [vaapi] 1920x1080 => 1920x1080 MPEG-4 VA-API Acceleration
[VD_FFMPEG] XVMC-accelerated MPEG-2.
Selected video codec: [ffodivx] vfm: ffmpeg (FFmpeg MPEG-4)
Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
AUDIO: 48000 Hz, 2 ch, s16le, 448.0 kbit/29.17% (ratio: 56000->192000)
Selected audio codec: [ffac3] afm: ffmpeg (FFmpeg AC-3)
[AO ESD] latency: [server: 0.19s, net: 0.00s] (adjust 0.19s)
AO: [esd] 44100Hz 2ch s16le (2 bytes per sample)
Starting playback...
Movie-Aspect is 1.78:1 - prescaling to correct movie aspect.
MPlayer interrupted by signal 11 in module: decode_video
- MPlayer crashed by bad usage of CPU/FPU/RAM.
  Recompile MPlayer with --enable-debug and make a 'gdb' backtrace and
  disassembly. Details in DOCS/HTML/en/bugreports_what.html#bugreports_crash.
- MPlayer crashed. This shouldn't happen.
  It can be a bug in the MPlayer code _or_ in your drivers _or_ in your
  gcc version. If you think it's MPlayer's fault, please read
  DOCS/HTML/en/bugreports.html and follow the instructions there. We can't and
  won't help unless you provide this information when reporting a possible bug.
Can anyone test it?
And how you launch you 1080p mp4 video?
PS: I have a FIT PC2
smattr
Re: mplayer and hd movie "Bug Buck Bunny" crash
Post by smattr »
I had this problem with playing a video with mplayer on a basic Fit-PC Linux Mint install too. Oddly installing the mplayer package (which uninstalls mplayer-vaapi) fixed this issue.
Video performance was still a bit sketchy til I removed compiz as well.
Return to “Linux Mint”
