Sorry for my english
My fitpc 2 freeze and crash when nobody use it
I was under ubuntu 9.10, it works fine for several month, and the bug was there, i decided to install ubuntu 10.04
The Poulsbo driver is installed
I suspect it come from hibernation, or something. I managed to stop the screensaver, but it crashes also.
Could you help me to fix it.
Maybe i should try to read log files ?
Or is it a hardware problem ?
THank you
eric
Fitpc freeze and crash
Re: Fitpc freeze and crash
Try changing to an virtual terminal (e.g. ctrl alt F2 ), if you can see a login prompt, login and kill the gnome login panel process. Then try switch back to x (should be on ctrl alt f7).. maybe you have to redo this a couple of times. Do resolve the problem, prevent the display (hardware) going to sleep and disable power saving.
Have a look at http://www.fit-pc2.com/forum/viewtopic.php?f=9&t=1666
It helped me a lot
It helped me a lot
Nothing changed : this is maybe the bug in the kernel on atom cpu, related to suspend function.
https://bugs.launchpad.net/ubuntu/+sour ... bug/657990
I try to keep an active window, with an active process, and it crash after a longer time.
I hope this will be fixed someday
