My Fit-PC2 can't keep the time
monnier
Post by monnier »
I'm having serious trouble with time keeping on my machine (using Debian testing). I'm not talking about a slow drift: it can easily lose more than 30min per hour. Here is an example session:
# (export TZ=UTC LANG=C; while sleep 60; do echo $(su - monnier -c "ssh fmsmemgm date"; hwclock; date); done)
Wed Apr 21 15:27:35 UTC 2010 Wed Apr 21 15:27:36 2010 -0.328802 seconds Wed Apr 21 15:27:35 UTC 2010
Wed Apr 21 15:30:35 UTC 2010 Wed Apr 21 15:30:36 2010 -0.172800 seconds Wed Apr 21 15:30:35 UTC 2010
Wed Apr 21 15:36:38 UTC 2010 Wed Apr 21 15:36:39 2010 -0.547803 seconds Wed Apr 21 15:31:38 UTC 2010
Wed Apr 21 15:52:41 UTC 2010 Wed Apr 21 15:52:42 2010 -0.703776 seconds Wed Apr 21 15:32:41 UTC 2010
Wed Apr 21 15:53:44 UTC 2010 Wed Apr 21 15:53:45 2010 -0.594683 seconds Wed Apr 21 15:33:44 UTC 2010
Wed Apr 21 15:59:47 UTC 2010 Wed Apr 21 15:59:48 2010 -0.641850 seconds Wed Apr 21 15:34:47 UTC 2010
Wed Apr 21 16:00:49 UTC 2010 Wed Apr 21 16:00:51 2010 -0.813433 seconds Wed Apr 21 15:35:50 UTC 2010
Wed Apr 21 16:11:52 UTC 2010 Wed Apr 21 16:11:54 2010 -0.985030 seconds Wed Apr 21 15:36:53 UTC 2010
According to the "sleep 60", the loop should run about once per minute, but it sometimes ends up waiting five minutes or more. I'm running ntpd on this machine. Have also tried openntpd but it did not help.
I do not see anything relevant in the syslog files. Dmesg sometimes gives me tons of "set_rtc_mmss: can't update from NN to MM", but not always.
The weird thing is that this exact same Debian installation was working perfectly fine at the very same location (tho on different hardware: I just took out the drive, replaced the big tower with the tiny Fit-PC2 and replugged the disk). So my suspicion is on the Fit-PC2.
Has someone seen something like that?
redada
Re: My Fit-PC2 can't keep the time
Post by redada »
i have the same problem here.
Have a look at this thread:
http://www.fit-pc2.com/forum/viewtopic. ... =clock+lag
I send my FitPC back to Compulab for further investigation on this.
Have a nice day.
redada
monnier
Post by monnier »
I'm glad to see it's not that I was doing something silly.
But w.r.t to the information in the above topic, my tests indicate that even disabling DPMS altogether doesn't help, and as mentioned earlier enabling NTPD didn't help either (because the instability of the clock is much larger than what NTPD is designed to handle).
Did you try changing C-States in BIOS to GV3 only ?
See http://fit-pc2.com/forum/viewtopic.php?f=11&t=512
monnier
Post by monnier »
irads wrote:Did you try changing C-States in BIOS to GV3 only ?
I first tried to keep C-states but disable the "extended C-states", but that did not help. Then I disabled the C-states altogether (keeping GV3-only) and it seems to work correctly now. I also feel like it fixed a few other minor/vague issues I've had.
An interesting observation I've made is that (when I bump into this C-state bug), the time loss is almost always 299s. So it looks like occasionally it gets into a C-state and stays stuck there for 5 minutes. An interesting consequence is that a cron job that readjusts the time every minute is not sufficient, especially it won't prevent the watchdog from rebooting the machine (since 5min > 255s, as I have discovered after enabling the watchdog).
Golfy
Post by Golfy »
From my part, WinXP on Fit-PC was running fine since 2010 to now...
... today, even after many restart, windows clock is too fast (around 1s each 5).
I don't understand why there is no BIOS update or patch for this problem :|
Edit:
I've found two help :
1) ClockMon tools is a program that synchronize windows clock with RTC clock (http://www.softdevlabs.com/ClockMon/ClockMon.html)
2) Someone at answers.yahoo.com (http://answers.yahoo.com/question/index ... 006AAMzPcY) has wrote this :
1. Start->Run cmd.exe
2. net stop w32time
3. w32tm.exe /unregister
4. w32tm.exe /register
5. net start w32time
equitius
Post by equitius »
I have the same issue
I use my fitpc for astronomy and I need a very accurate clock. With ClockMon I can sync it every minute but that still leaves me up to 5 seconds out at any time which presents problems.
I have tried the register/unregister routine suggested to no avail.
Surely there is some other fix??
Pete
Have you tried the solution advised in the first post on that topic?
equitius
Post by equitius »
I've not been able to check the Bios as I run my fit remotely using VNC ie no monitor or keyboard.
I will check the status this week sometime.
I do find it odd that this has started only recently. I have read that the CMOS battery may be the culprit though the RTC looks like it keeps very regular time. Can you shed any light on this?
Pete
Return to “RTC & System clock”
