Force 1366x768 without screen attached Windows 7
Posted: Sun Oct 23, 2011 3:42 pm
I am running an eyetracker on the fit-pc (running Windows 7), and the gaze is defined by the current resolution. When I attach the new Toshiba USB monitor 14" 1366x768 the resolution changes from 1024x768 to 1366x768 (also in Real VNC). My problem is that I want to be able to run the eyetracker without a screen attached, and sometimes attach the USB monitor. The resolution needs to stay the same (1366x768), as the gaze estimation should remain the same with/without monitor attached.
I have tried PowerStrip software to change the resolution, but without any luck:(
Any way to solve this? BIOS setting, Windows setting, etc.?
