FITPC2 - Different Ethernet Controller Models?
Adrian
Post by Adrian »
Hi
We have an organization who we are working with on a project. We recently built a FITPC with the required configuration for the project, and this build was then cloned and the plan was to apply this clone to another 30+ FITPC2 machines.
The company we are working with has come back to us saying the clone is failing because the hardware on some of the FIT's is slightly different to the original 'template' FITPC.
At the moment we know that the ethernet controller seems to be a slightly different revision:
rtl8111D - D Controller
rtl8111C - C Controller
Can someone from FIT support please confirm whether different ethernet controller versions are being used in the FITPC2 builds?
Re: FITPC2 - Different Ethernet Controller Models?
See http://fit-pc2.com/wiki/index.php/Features#Ethernet
Are you sure you have not been using both fit-PC2 and fit-PC2i ?
Return to “Ethernet”
