No 1Gbps Ethernet
Posted: Mon Aug 09, 2010 6:19 pm
by Damike5646845646
i cant get 1gbit connection but my hardware support it switch (8 port gigabit) fitpc2I (Gigabit) LAN-wire cat.6 what is wrong? any solution?
Re: No 1Gbps Ethernet
Posted: Wed Aug 11, 2010 1:00 pm
The Ethernet ports of fit-PC2i do support 1Gbps. Please provide more details -
Is stated link 100Mbps or 1Gb
Which OS you are using
What is the actual rate you are seeing
Posted: Sun Sep 19, 2010 2:15 pm
by Damike5646845646
My OS id windows7 pro my switch is a Netgear GS108 ->Link http://www.netgear.de/Unternehmen/Switc ... index.html
my older PC does support 1GBIT on that port so it can't be a wiring mistake.
What is the actual rate you are seeing? What you mean? my transfer rate from one pc to an other is about 5,6MB/sek thats poor...
Posted: Sun Sep 26, 2010 5:02 pm
by Leonid
Hi.
The speeds you encounter were probably more a factor of the hard drives being used than the network connection.
For more information, please read the following article:
http://binglongx.spaces.live.com/blog/c ... =259621805
