Ethernet suddenly died
JacquesB
Post by JacquesB »
Both Gigabit network adapters on my Fit-PC2i suddenly stopped working. They don't show up in the Windows Device Manager anymore, and the physical lights aren't working as well.
I have tried the following:
- Reinstalled WinXP
- Reinstalled Win7
- Updated the BIOS to the latest version
- Tweaked virtually every setting in the BIOS
None of these actions made my network adapters reappear.
Does anybody have a solution, or do I have to send the Fit-PC back to Israel?
Re: Ethernet suddenly died
Sometimes the Ethernet controller may enter an unknown state that is reset only by disconnecting the power. Try that.
Please email rma@fit-pc.com for additional checks and unit replacement if needed.
JacquesB
Post by JacquesB »
Thanks irads. I'll try that when I get back home (which won't be until next weekend).
JacquesB
Post by JacquesB »
Unplugging it did the trick. Hadn't thought of that. Thanks a lot irads!
LEGOManiac
Post by LEGOManiac »
Wow. That's disturbing. I just received my FitPC2i yesterday and within an hour had lost one of the ethernet ports. I had presumed that heat had damaged something and was about to contact technical support.
How can I trust this thing for a remote installation if it does this and won't reset itself with a reboot? At least if it reset it self with a reboot, a script could be written to reboot the computer if an interface became unresponsive, but to physically have to cycle the power? That's a confidence buster.
There is no known HW problem with the Ethernet controllers. The discussion from May last year relates to controller firmware and Windows driver - both are sorted since.
Return to “Ethernet”
