Fit-PC2i Windows XP COM port issue
Posted: Thu Aug 26, 2010 12:07 am
by bobmitchell
We purchased two of these devices earlier this year and we are currently experiencing intermittent communication problems using the COM port with one of them.
To convince myself that this was not a software or configuration problem of some sort I used a simple test setup where I connect the COM port of the Windows XP Home Fit-PC2i to a Windows XP Pro laptop with a USB serial adapter. Then I simply configure the COM port for 19200,8,E,1 on both sides using the Windows HyperTerminal app and try to transfer a file. One of our devices does this reliably several times. The second devices fails intermittently. The same cabling is used for both tests.
My conclusion is that we may have some flaky hardware. However, I would appreciate any suggestions as to anything else I might do to rule out any other problems.
Thanks!
Re: Fit-PC2i Windows XP COM port issue
Posted: Thu Aug 26, 2010 3:20 pm
Please email rma@fit-pc.com
