Does anyone know where I can get a right angle mini serial connector or a right angle Mini Serial to DB9 Connector
The one that ships with the fit-PC2i can easily be broken off.
Thanks for any help / advice.
Best Regards,
XtremeVision
The connector is proprietary. It would not be easy to obtain an off-the-shelf replacement.
If you install where the cable my be pulled off I suggest to secure both the computer and serial adapter to prevent them from moving.
