Dual ethernet
The requests in this sub-forum has been addressed with announced or soon-to-be-announced products
pong
Dual ethernet
Post by pong »
Are there plans for a fit-pc2 with dual ethernet? I'd buy one immediately to replace my zyxel firewall, which only gives me 13 mbit/s IPSEC DES throughput, before the CPU maxes out. SOHO router/firewalls with VPN support are relatively expensive if you want >20mbit/s 3DES IPSEC throughput.
Re: Dual ethernet
Thanks for the input.
We are aware of the demand for such a product. It has been thoroughly discussed on www.fit-pc.com/forum since the introduction of fit-PC Slim.
CompuLab discusses only announced products.
pong
Re: Dual ethernet
Post by pong »
irads wrote:Thanks for the input.
We are aware of the demand for such a product. It has been thoroughly discussed on http://www.fit-pc.com/forum since the introduction of fit-PC Slim.
I don't need a gigabit WAN interface, so I'll just buy an USB 2.0 Ethernet Adapter. The Apple USB Ethernet Adapter looks appropriate.
Liberio
Re: Dual ethernet
Post by Liberio »
Indeed, it would be usefull to fit the next version of fit-PC out for dual ethernet.
lazytt
Re: Dual ethernet
Post by lazytt »
+1 for dual (or even tri) ethernet
jernej
Re: Dual ethernet
Post by jernej »
+1 for dual ethernet
jernej
yogev_ezra
Re: Dual ethernet
Post by yogev_ezra »
+1 for dual Ethernet.
It's a pity that device as small as this cannot be used as a proper router (i.e. with both Ethernet ports soldered on board, and not via USB dongle). Of course in this case, audio and IR connections are probably unnecessary, so it could provide the space for 2nd (and even 3rd) Ethernet port.
pellen
Re: Dual ethernet
Post by pellen »
With dual ethernet it would be the perfect router/gateway :) Getting tired of my p3 500mhz in the old, ugly and big compaq case drawing ~50w idle
teaguehopkins
Re: Dual ethernet
Post by teaguehopkins »
+1 dual gigabit ethernet.
In a similar vein, any kind of secondary high speed connection would be better than nothing. eSATA or Firewire 800, but I think dual ethernet has the most applications.
dejot
Re: Dual ethernet
Post by dejot »
+1 for dual ethernet.
will probably still buy, but emulate ethernet via usb. any experiences with that?
Locked
Return to “Addressed requests”
