RHEL/CentOS errors with ide controler
lazytt
Post by lazytt »
The fit-pc2 uses the Intel US15W (Poulsbo) chipset which includes the ide controller. It seem this chipset is not supported by centos. The ramifications of this lack of support include:
  1. No dma. Disk write speeds are ~2.2MB p/ sec
    /dev/hda:
     Timing buffered disk reads:    8 MB in  3.51 seconds =   2.28 MB/sec
  2. improper (read=no) shutdown of the hard drive which conserves energy and helps keep the unit cool. (my unit runs to hot to touch for more than 3-4 seconds). this is the error:
    hda: status timeout: status=0xd0 { Busy }
    ide: failed opcode was: unknown
    hda: no DRQ after issuing MULTWRITE_EXT
    ide0: reset: success
Please let me know if there is a solution for this issue.
sndralex
Re: RHEL/CentOS errors with ide controler
Post by sndralex »
Which hard disk did you use?
I don't know whether it is important or no, but this chipset has only PATA controller, not SATA. According to the Intel's spec.
lazytt
Post by lazytt »
i used the compulab included hd, whatever that is. From my understanding, the translation from pata to sata is invisible to the system, hence, if I cant cant set dma, is because the system cant relate to the chips set - irrelevant on the HD itself
yogev_ezra
Post by yogev_ezra »
What CentOS version did you use? I plan to install CentOS myself soon.
lazytt
Post by lazytt »
yogev_ezra wrote:What CentOS version did you use? I plan to install CentOS myself soon.
5.3 (I used the asteriskNOW iso). Let me know how it goes!
sndralex
Post by sndralex »
Could you try this distributive?
http://ftp.uni-bayreuth.de/linux/redhat ... 5xx-US15W/
I understand that it's not a AsteriskNOW, but, may be it will work.
P.S. I'm actually interesting in fit-pc2 to be my router/firewall/sql/web-server, and I prefer rpm-based distributive.
lazytt
Post by lazytt »
sndralex wrote:I'm actually interesting in fit-pc2 to be my router/firewall/sql/web-server, and I prefer rpm-based distributive.
Same ehre, but I already have my server up and running (although without dma), so I'de rather not reinstall it now. Anyone else? Perhaps tehre is some driver/kmod that we can extract?
lazytt
Post by lazytt »
It seems that support the for ide controler was added to the linux kerner about version 2.6.25. Here is a link to said module. Perhaps someone can compile it for 2.6.18-128.1.1.el5?
UPDATE: Said module was first publicly released in kernel 2.6.26
lazytt
Post by lazytt »
hmm, I wonder if there isnt a problem with the hd itself. I've had to recover many times from journal error's. I get this error:
kernel: journal commit I/O error
lazytt
Post by lazytt »
I've managed to compile what I believe is the appropriate module (taken from the 2.6.30 kernel) agents 2.6.18-128.1.10.el5. After doing modprobe libata, I can load the module with insmod pata_sch.ko
However, here I still cannot enable dma. Here is the demsg output:
libata version 3.00 loaded.
pata_sch 0000:00:1f.1: version 0.2
pata_sch 0000:00:1f.1: 0x1F0 IDE port busy
PCI: Setting latency timer of device 0000:00:1f.1 to 64
scsi0 : pata_sch
scsi1 : pata_sch
ata1: DUMMY
ata2: PATA max UDMA/100 bmdma 0x1818 irq 15
Attached is the compiled module
pata_sch.rar
(52.86 KiB) Downloaded 979 times
